I want to run 12.7
Re: I want to run 12.7
Originally Posted by neil350
You'd think but if you read the boards now a days you wouldnt. Your right an auto with a converter, cat back, cold air and set of gears should easily be a 13.0 car. People have hit 12s in the past with those mods.
Fastest is at like a 12.7 I believe, Its not impresive but a 13.0 for a cat back, cold air, gear converter car is about what it should run consistant for those mods maybe dip in to a high 12.
A 12 second car is verry fast imo. I was verry excited and impressed when i ran a 14.4 stock. It was my first and only time to a track granted. Most of the mustangs and camaros when i went(highschool nationals)we running high 14's low 15's and their were around 1,000 people with cars. Hopefully when my car is done ill dip into 12's. Then i can finally get that peksy neon srt4 that allways beats me.
I would hope your built tranny has a nice converter in it. Now get sticky tires, headers, better catback, good cold air induction, and lighten up the car.
I know of a few cars running mid 12's with bolt ons, so its very possible, even without a converter.
Although the cheapest way is N2O.
-Dustin-
-Dustin-
There is a million different ways to get the times he wants, but he asked for the cheapest route. N2O is the cheapest, hands down. For ~$1000 he could buy and install N2O and run those times.
You guys make it sound like 12.2's are nothing....with bolt-on's. I would like to see someone run a 12.2 straight out first run with just bolt-on's....yes it can be done....but it can't be repeated as easily as you state here.
I can vouch for SSMark. I ran up against him this Oct. He's actually ran faster then he did in the vid below.
http://www.v8havoc.com/stuff/mevsz28.MPG
I know a fellow with a LT1 M6. CAI/LT/Catback/4.10's, DR, carbon fiber DS and a few other small mods running 12.4X Of course I wish I could be there. It can be done but patience is key.
-Dustin-
-Dustin-
The last time at the track the best I could pull was a 13.1 @103.xx
It may be the opti though so i may change that out in the spring. Regardless I am thinking about building a LE3, stock block and a bigger stall. Until I get the turbo motor done of course
Oh and I have a vig 2800 and 3.73 gears, full race weight minus skinnies for the 12.7.
-Mark
Originally Posted by White Knight
THose must be freaks and fresh motors....a 12.2??? My car has yet to go under 13.5 with a 1.78 60' I really wish someone could find out my problem.
Smokn '94 Z
Jul 28, 2002 02:38 AM
