i want to ditch my 224/230
Old Feb 17, 2005 | 11:54 AM
  #16
worak's Avatar
Re: i want to ditch my 224/230
Originally Posted by turbo_Z
Did you put it together yourself or did a shop do the work? Reason I ask is it may be possible the timing chain is off a tooth unless you can varifiy it isnt.
shop did the work. how could i tell if it was off one.
Old Feb 17, 2005 | 12:06 PM
  #17
turbo_Z's Avatar
You would have to take the timing cover off and look. Id just ask the shop what they did. It should be put on straight up or both dots on the gears should be at 12 o'clock. I dont see how a decent shop could get it wrong but they may have tried to advance the cam a couple of degrees like the old school builders liked to do.
Old Feb 17, 2005 | 12:33 PM
  #18
worak's Avatar
the guy that did the work is well respected in the area for what he does. im 99.9% sure he lined the dots. would a larger cam need a retune?
Old Feb 17, 2005 | 12:58 PM
  #19
turbo_Z's Avatar
Yes however your problem is not the cam.. its hte motor so figure out what is wrong with the current setup and then youll be happy. I wouldnt rule out the heads either since you changed those also.
sahlomonic
Parts Wanted
Sep 19, 2015 10:17 AM
POLOVETTE 94
Aug 21, 2015 07:11 PM
Jun 6, 2015 08:27 AM
LimitedEd1LE
May 18, 2015 01:24 PM
Chris 96 WS6
Advanced Tech
29
Feb 23, 2003 07:10 PM
