i wanna get 400 ponies! help
Rich
Do not post offers to sell in the tech forums. Use PM or e-mail.
Re: i wanna get 400 ponies! help
To give you an idea, my car put down 349 to the wheels on a mustang dyno with 0 miles on the engine. We basically went through a break in procedure on the dyno and did not rev past 5900. There is definitely more in it.
I run a very small cam from AI that passes NYC emissions and their 200cc stock ported heads. Car drives like stock, has a very broad power band and has an auto.
With a slightly more aggressive cam and an M6, 400 rwhp is no problem.
Intake, cam( be sure to replace your valve springs), rocker rollers too, long tubes, full exhaust, injectors, good head work( minimum 75 bhp assuming their done right), and tune. Your rear end and clutch should hold just fine but gears will help you get off the line faster.
Henson071
Sep 21, 2015 04:31 PM
