I turned the key in the ignition, the dash lit up, but the starter didn't go
Old Nov 6, 2003 | 11:06 PM
KillerTA's Avatar
Like the title says, the engine wouldn't start and the starter didn't make a noise. The car has never had starting problems before and I'm pretty sure that the starter and battery are fine. After about fifteen minutes of trying, the car finally started. This happened once before too.
Do you think the ignition cylinder is dirty and the pass key wasn't working right? Other than that, I have no clue. What do you think?
Old Nov 6, 2003 | 11:14 PM
jasons93z's Avatar
Yes, it sounds like your ignition switch my need some "tweaking"
Old Nov 6, 2003 | 11:16 PM
Besides battery and starter, it could be anything from battery cables to ignition switch, to theft deterrent relay. If your security light was on, then it would have something to do with the VATS.
liamcg97
Nov 25, 2019 05:55 PM
eazyZ
Mar 1, 2015 07:12 AM
warmeck
Feb 5, 2015 11:04 AM
97z28k&N
Jan 9, 2015 04:58 AM
A's 91 Z28
Dec 7, 2014 12:09 PM
