i think my trasmission's losing it...
Old Mar 1, 2004 | 10:32 PM
st08x's Avatar
so i'm about to turn onto the access road and the highway entrance is right there, i have a 93 z28 a4, so i drop the shifter down to 1st to controll the fish tail action a little bit, so i get on the highway and then the next time i try to put my car in reverse it doesnt go, it wasnt in neutral but it wasnt in reverse either, it felt like it was pulling but it wasnt moving anywhere, so i have a friend help me push it out of the spot cause drive still worked and then when i tried to take off it was taking off in 4th gear in drive so i'm like wtf?, my friend suggests putting it manually into 1st and see if it will go, it does, and then magically my drive and reverse start working normally again i don't get it, it works now but was that just a strange mechanical fluke or should i get it looked at? i check the tranny fluid and it was still fairly red and at a decent level, it didnt smell bad or anything, any advice? it has 101,000 miles on the original drivetrain
Old Mar 1, 2004 | 10:51 PM
Jay-Roll's Avatar
It's possibly your tranny. Ours are known to go at around 100,000 give or take a few thousand. So it's definately a possibility. Also check your linkage. It might have got tweaked or something when you dropped the car down to 1st. I doubt that's the culprit from what you described, but it'd be a lot cheaper and easier than a tranny rebuild.
Old Mar 1, 2004 | 11:22 PM
RED95LT1Z28's Avatar
It could be your linkage that happened to me. Mine wouldn't go into park or reverse. I put it in first and it stuck there because the linkage was broke. I couldn't put it in park or reverse or anything but the shifter moved.
Old Mar 2, 2004 | 12:20 PM
st08x's Avatar
well it's been shifting, reversing, fine all day, but i don't know how long that will last, should i go get it looked at/serviced or something?
F'n1996Z28SS
Aug 23, 2023 11:19 PM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
cmsmith
Sep 14, 2015 09:25 PM
surreybrad
Aug 10, 2015 09:34 AM
alex5366
Jun 14, 2015 10:27 PM
