I think im in trouble!
Flushin my coolant and when took off the thermo to flush block, coolant got all over opti. And I accidentally spilled water from the hose onto it becuase i cant freakin aim into the water pump! What the hell does this mean??????? I just got opti replaced 30k miles ago and I dont wanna do it again! What should i DO!
You should be ok man, your opti was designed to withstand being wet. Granted it wasnt designed to get soaked with coolant i dont think its going to hurt it as long as you cleaned it off. Do you see any signs that the opit is messed up (feel like spark is retarding?), becuase if you dont now you most likely arnt going to later.
Aug 7, 2015 01:26 PM
