I Think I'm Gonna Do the Brakes 1st Timer...
Old Nov 26, 2003 | 06:38 PM
joecool72's Avatar
I finally picked up a set of GM shop manuals on the Z28 at so I was going to browse through it the next couple of days and maybe try and do them Sat. or Sun. What do you guys think? Will it be easy enough for a novice? I'm a fairly technical person, all I needed are the manuals to follow and I was told it's actually an easy job. I'm not going to do anything fancy, just OEM replacement. Should I also go to OEM comparable ceramic pads?
Thanks in advance!
Old Nov 26, 2003 | 07:03 PM
Tibbys96Z's Avatar
yes it is easy. worst part for me is moving the jack around the car...
Old Nov 26, 2003 | 07:41 PM
1996 | Z28 SS's Avatar
It's very easy, especialy if you have a manual. Go for it and follow the steps.
Trevor
Old Nov 27, 2003 | 07:52 AM
Bud M's Avatar
Doing a pad swap is easy but its a good idea to have the rotors turned for best brake performance.
Old Nov 27, 2003 | 08:31 AM
S.J.S.'s Avatar
My grandma could do the brakes if she tried. Go for it buddy.... good place to start.
May 1, 2015 01:14 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
Red97LT1
9
Dec 17, 2014 06:13 PM
simple
Aug 2, 2002 03:30 PM
