question about air intake
Old Nov 26, 2003 | 05:30 PM
mr_camaro96z28's Avatar
The rubber hose that fits onto the throttle body has a nice 2 foot or so piece of plastic that drops off the bottom in front of the motor, every camaro ive seen has it. ive been told its a silencer keeps down on the air noise. my question is how do i get rid of it a friend said something about a free mod whatever that means i just want it gone.
Old Nov 26, 2003 | 05:34 PM
S.J.S.'s Avatar
They sell after market ones like the Trick Flow and Vortech elbows but they are kinda spendy, like 90 bucks. You can get the 1le rubber replacement one, basically looks like the stock one without the donkey dong. That one is like 60 bucks.
Old Nov 26, 2003 | 05:37 PM
where do i get either one of those?
Old Nov 26, 2003 | 05:40 PM
S.J.S.'s Avatar
Just about anywhere I guess. Summit, Jegs, Thunder Racing. Even Ebay has the 1le all the time for like 65 bones.
Old Nov 26, 2003 | 05:42 PM
alright thanks for the info. if anyone else has input im open.
Old Nov 26, 2003 | 05:54 PM
Heatmaker's Avatar
Advanced Member
Invest in a Vortech elbow. Skip the 1LE. THe aluminum elbows look 100000000times better when you lift the hood. Plus the 1Le's are annoying if you plan on doing work. You have to remove your eblow for Darn near everything.
Old Nov 26, 2003 | 06:31 PM
How would i go about getting a vortech elbow and what do they cost
Old Nov 26, 2003 | 06:44 PM
Jeff H's Avatar
The downside to the Vortech aluminum elbow is that it will conduct heat and raise your intake temp. It looks a lot better, but if you lose power due to the heat, then why bother.
Old Nov 26, 2003 | 06:54 PM
Heatmaker's Avatar
Advanced Member
Get the Vortech. The heat issue is about the fact that it's made out of metal rather than rubber...but the Vortech elbow is better constructed to flow air. It has a wall inside of it that guides air directly to the TB ports. The Trick flows don't have that but the Vortechs do. Vortech is like 8 more bucks or so like 90 or something. You can get the Vortech Elbow from Summit.com Forgot where I got mine exactly. Maybe Thunderracing.com. Don't worry about loosing any HP you wont. It's very possible to gain HP with the better flowing intake elbow. Heatsoak will coast you like .00000023hp if it ever becomes a factor. NEver heard any compaints.
Old Nov 26, 2003 | 08:03 PM
96LT1Fan's Avatar
Doesn't the vortech elbow prohibit you from using a TB airfoil?
Old Nov 27, 2003 | 09:00 AM
the vortech sounds like a good elbow but that kind of expensive right now i just bought lt1 edit so im kinda broke. if theres a cheap was for know that would be good.
rjc1629
Jan 27, 2015 10:46 AM
30thZ4C
Dec 26, 2014 05:09 PM
thenewkid
Nov 27, 2014 09:41 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
squirrels
Jul 13, 2002 01:58 AM
