I think I'm going to use the copper header gaskets that came with my MAC's
Old Jan 27, 2004 | 11:36 AM
stereomandan's Avatar
Seems like no matter what header gasket I see recommended, someone has had them leak.
I fugure, what the heck, the one's that came with my MAC's look like a very nice copper gasket.
I'm also going to use the header bolts that came with them.
I may regret it later, but it's worth a try. They look like 1" bolts with a 3/8 head.
What do you guys think. Anyone done this before? Seems like everyone is getting fel-pro, dead soft aluminum, Stock GM gaskets.. and using Stage 8's or splitlocks...
Dan
Old Jan 27, 2004 | 12:15 PM
IDOXLR8's Avatar
In all honesty I would just bite the bullet and use some GM header gaskets with the swap. If you decide to run Stage 8 header bolts with your setup you will have to modify the washers that come with the kit.
Old Jan 27, 2004 | 01:41 PM
RE AND CHERYL's Avatar
Cool
I don't know what coper gaskets Mac includes with their headers, buy every coper gasket I've used so far has been awsome with no sealing problems. I'm going to buy them for my AS&M headers when I put them on.
Old Jan 27, 2004 | 01:50 PM
KGRESOCK's Avatar
Dan,
Iv'e tried several different combinations of header gaskets
and bolts.
FWIW
this is what has worked best for me.
Earl's dead soft aluminum gaskets with a 2" cap screw
with a 1" brass sleeve (available at sears hardware)
NO leaks, I have good access to tighten all bolts
and it looks trick.
Shoot me a PM if you'd like some pics.
Kevin
Old Jan 27, 2004 | 01:58 PM
94YellowTAGT's Avatar
I bought stage 8's when i first did mine. Some how the all worked there way loose. So i went to oriellys and got some cheap bolts there. They haven't loosend yet.
Midnight_Z
Feb 16, 2016 09:36 PM
dylan1303
May 22, 2015 12:24 PM
94Z28LS1toLT1
Apr 7, 2015 05:37 AM
rick350
Mar 16, 2015 02:59 PM
Jazsun
Dec 29, 2014 12:14 PM
