I talked to comp cams today.
Old Apr 10, 2006 | 11:39 AM
1993z28camaro's Avatar
The guy I talked to said that the 07-466-8 cam would work the best for a bolt on lt1 w/6-seed tranny. It seems a little low to me though the specs are 218intake 224 exhaust and 570intake and 565 exhaust w/1.6rr. This seems like an LT4 hotcam with more valve lift on the exhaust and intake but the duration is the same as the LT4 hotcam and it scares me to think the cam maybe to small. Don;t want it to be done twice. He said the cc305 wouldn't give me as much power as this cam. The duration is 220intake and 230exhaust and I'm not sure on the valve lift. So what do you guys think? Go big or go home or listen to the professional?
Old Apr 10, 2006 | 11:44 AM
Mike96z's Avatar
Re: I talked to comp cams today.
cc468 is bigger and it's .584/.579 242/248 and the cc306 is a great cam too with 230/244 .510/.540 but when your duration gets bigger your loosing lower end. I would go with one of these cams I just listed because you can get a better cam than the LT4 with your money.
Old Apr 10, 2006 | 11:47 AM
stereomandan's Avatar
Both of those cams are way too big for a car with stock heads in my opinion. You will lose a ton of low end TQ, and never reach the potential of those cams with stock heads.
The cam the original poster listed would be great for the street, with stock heads, and good valve springs.
Dan
Old Apr 10, 2006 | 01:55 PM
THe cc468 and the cc306 are way to big for my application right now. I need something that is still streetable thanks.
Old Apr 10, 2006 | 05:13 PM
to small?
Old Apr 10, 2006 | 09:02 PM
89TramsAmGTA's Avatar
The 07-466-8 cam suggested by Comp Cams is the XFI 268. It has agressive ramps and acts like a bigger cam. At .200 lift it has 143 degrees of duration which is as big as some of the older 230 degree cams and much higer lift which is a good thing. It is a much better cam the the "old school" 218 hot cam. IMHO they gave you good advice.
Old Apr 10, 2006 | 10:21 PM
huskersZ's Avatar
I went through this same thing a few years back. I ended up going with the 227/233 combination motorsports grind which is a comp cams xe grind (look it up on their website). I really like this cam. I have 6 speed with all the bolt ons, and 4.10's in the rear, and have to say the low end and the top end is good with this cam, throwing it up to third on burnouts are no problem with this cam (ie has good torque). Cam has pretty good street manner with very little surging after I had it tuned. My heads were very mildly worked when I did the cam swap, mainly just a good valve job, and made sure the springs were installed at the correct height. Hope this helps you choose.
Old Apr 10, 2006 | 10:27 PM
194bird's Avatar
go bigg look at some of the power the 847 cam is making with stock heads and the 230/236
Old Apr 10, 2006 | 11:17 PM
urbaNHunter44's Avatar
search around for threads on the cc305 and the cc503. I see alot of people pulling 345 rwhp out of them with stock heads.
I think I'm going to go with the cc305.
Old Apr 11, 2006 | 01:38 AM
tritonium's Avatar
I went with the CC305 in the middle of rebuild ill let you know ASAP -- anyone know the right length for the dowell pin on it for the opti? for the 95 + opti ( mines a 93 so ihhad no pin to compare it to. did the vented convert
Old Apr 11, 2006 | 05:05 AM
BA383TA's Avatar
Listen to the Comp Cams guy. There is no reason for him to point you to the wrong cam for your setup since cams are their business and he's not recommending his brand over another companies cam.
RUENUF
Mar 13, 2016 03:39 PM
oldschool
Feb 9, 2016 09:21 PM
MadMav
May 25, 2015 09:35 PM
carl.froehlich
Mar 13, 2015 12:38 AM
alliance12364
Mar 6, 2015 04:39 PM
