Car sounds like a Diesel
Old Mar 5, 2006 | 07:29 PM
Koby's Avatar
Question Car sounds like a Diesel
Ok, not all the time, but it is enough to be annoying. It mainly sounds the worst when I just start it up and it is cold outside. After it warms up then it isn't so bad, but I can still hear it sometimes. Anybody know what could be causing this? Obviously the higher the rpm the louder it gets. I never have this problem in the summer when it is warm, only in the cold...
Old Mar 5, 2006 | 07:34 PM
Z28LT1_Just_Nasty's Avatar
Re: Car sounds like a Diesel
What do you mean sounds like a deisel? Explain.
Old Mar 5, 2006 | 07:56 PM
Schweet97Z's Avatar
probably piston slap. gm vehicles are notorious for that. is there anyway you could get a video or sound clip of the car when its making the sound?
Old Mar 5, 2006 | 10:35 PM
Koby's Avatar
I probably could get a video of it....now uploading it and hosting it could be another problem. It has just started doing it recently, but it is very annoying. It is hard to explain without somebody hearing it. It really does sound like a diseal engine, but only when it is really cold. Seems like once the engine gets warm or even after a minute or so of driving it sounds pretty much like normal. The sound is always there is seems, just much quieter after the initial noise. I'll try to get a sound clip of it.
Old Mar 5, 2006 | 11:20 PM
2fast97z's Avatar
yeah def sounds like piston slap..try to get a video up
Old Mar 5, 2006 | 11:33 PM
Schweet97Z's Avatar
once you get a video you can send it to me and ill host it for you, or you can host it yourself through www.putfile.com just set up an account and upload the vid. its really simple and straight forward
turbo_Z's Avatar
Thats normally what ppl say when they have piston slap.
Old Apr 10, 2006 | 10:06 AM
ibanez6rg's Avatar
Most likely piston slap, you can either deal with it or get it fixed. Either way, it won't hurt your motor.
Old Apr 11, 2006 | 05:32 AM
Guest47904's Avatar
Guest
When last I checked, piston slap doesn't sound like a diesel engine. My Vortec engine had the same problem. Just came out of nowhere when it turned cold. The coolant level was a little low. It turned out to be the intake gaskets where leaking until the engine warmed up and then sealed up.
I suggest you check both the resevoir and the radiator level if it's been doing it for a while.
AdsoYo
May 2, 2018 03:21 AM
fpete1992
Dec 11, 2014 03:51 PM
jayblev95
Dec 1, 2014 06:55 AM
USAirman93
Nov 24, 2014 03:37 PM
Klypto
Jul 24, 2002 11:21 AM
