i set a goal. Help me get there
Old Oct 21, 2003 | 07:35 PM
gritter's Avatar
Today i did some thinking on the time i want the t/a to run after winter. I wanna run a 12.8 1/4 mile or better by next summer. The car is a 1994 A4 trans am. The only mod to date is a flowmaster catback exhause. What mods should i do that will get me w/ traction of course 12.8 or better? Thanks for the help guys i really hope i can meet my goal.
Old Oct 21, 2003 | 07:56 PM
Aeromaks's Avatar
a 200 shot. =)
Old Oct 21, 2003 | 08:07 PM
Geezer powered's Avatar
he said high 12's not mid 11's. You only need a 75 shot to get there
Old Oct 21, 2003 | 08:14 PM
gritter's Avatar
shoulda clarified a bit more, sorry. Wan't this to be all motor.
Old Oct 21, 2003 | 08:21 PM
drewstealth's Avatar
Get yourself a CAI(K&N fipk, SLP, Moroso) first. They are all basically the same so get which you think looks best. Then either get yourself a better catback or get a cutout. You should also get some gears, stall, and some drag radials. From there i would get some good headers. LT's if you don't have to worry about emissions. If you do then get either macs, slp's, or as&m's. From there you can get a cam and that should put you around mid 12's. But if your just shooting for 12.8 you could possible get it with some 1.6 or 1.7 rockers. With those mods you should be there. Just make sure your car is running top notch.
Old Oct 21, 2003 | 08:41 PM
nitropatch's Avatar
on my 97 A4 i when 12.9 witha gear, MSD6A, Cold Air costum, 1.5 crain gold roller rockers, and throttle bypass, and 2400 stall, futura's tires.
good luck
Old Oct 21, 2003 | 08:50 PM
S.J.S.'s Avatar
Gritter....there a lot of different combinations you could go with. The first thing you GOTTA get is a CAI kit. That's the one must you should have and the most bang for the buck. The engine gotta breath. Next thing you gotta get is the headers. After that you can go in all different combos. I would go with the converter for sure and possibly a cam package like the HotCam kit which comes with 1.6 rr's, springs and everything for 490 shipped. That should get you there.
Old Oct 22, 2003 | 01:50 AM
nitropatch's Avatar
that would get him there but i would get the gear before the hot cam kit but thats just me
Old Oct 22, 2003 | 01:52 AM
NewbieWar's Avatar
probably not the right spot for this question but why do so many people pretty much hybernate their f-bodys during the winter?
does it not run at cold temps or something?
Old Oct 22, 2003 | 04:54 AM
gritter's Avatar
ever try driving a rear wheel drive car in the winter? Let alone a rear wheek drive car with some power? Also the salt they put on the road hurts the paint i think.
Old Oct 22, 2003 | 09:00 AM
NewbieWar's Avatar
well i live in cali, been driving a rear wheel drive all my life
but i did go to the grand canyon last winter, in my truck and heh i lost traction a few times and yea something made my truck all dull
ok just didnt make any connections... thx
Old Oct 22, 2003 | 10:53 AM
Yeah here in cali i don't think we have to worry about winter as much. Ecspecially where me and you live there isn't any snow. But sometimes when it rains real bad it sort of sux to drive a rear wheel drive car with power. At that point i sort of miss my AWD.
Old Oct 22, 2003 | 11:01 AM
TedH's Avatar
Mild port job, mild cam, headers, cat back, cold air, drag radials, 2800 stall converter, and decent driving should basically do it. There are other details that you may "want", like looser shocks in front to help with the launch, shift kit, gears, but the above mods should easily get you there.
Old Oct 22, 2003 | 01:14 PM
T/A lt1's Avatar
A couple years ago I had a Flowmaster muffler as my only mod and my car ran 13.80's. The car had over 130k miles and I wanted to run 11's with N20 here is what I did. I pulled the heads off and me and a friend cleaned up the heads (very little portwork),I installed a Hotcam kit, some AS&m headers and a Vigilante 2800 converter. I had someone send me a mailorder tune and off to the track I went. With worn out Et streets the car ran 12.69@105mph in 100degree weather with stock 3.23 gears and a 3750lb raceweight and stock 17's on the front. Over the next few months I tuned on it, put skinnies on it and swapped a set of 3.42's in. I got it to run 12.30's@110mph in better weather, awesome combination. I then sprayed a 150 NX shot and ran 11.30's @118mph not even spraying the whole 1/4 I have since swapped setups b/c the car is no longer a dailydriver and my goal is now 10's@125+mph .
HectorM52
Jul 30, 2017 11:46 AM
z28leno
Mar 12, 2015 07:42 AM
FredM
Mar 6, 2015 03:04 PM
Jan 23, 2015 01:13 PM
Doug Harden
29
Jul 30, 2003 07:05 AM
