A.i.r thingy on passenger side exhaust manifold.... broke.. *pic*
Old Oct 18, 2005 | 05:16 PM
sabre81's Avatar
It broke off where the red arrows point to in this pic.
http://sabre81.dontexist.com/stuff/diverters.jpg
Can i just delete this hose? should i delete a.i.r completely? Help!
Old Oct 18, 2005 | 05:25 PM
Re: A.i.r thingy on passenger side exhaust manifold.... broke.. *pic*
Which part broke? Two parts join at the arrows you show. It's up to you whether you want to replace or delete.
Old Oct 18, 2005 | 05:27 PM
sabre81's Avatar
The threads on the shiny object coming from the exhaust manifold broke, right were the arrow points. Any side effects to deleting it? what do i plug the exhaust manifold with?
Old Oct 18, 2005 | 05:59 PM
will62085's Avatar
the pic didnt work, and its supposed to be there for emmissions, but the car will pass without it as long as the tech guy doesnt notice its no longer there...
Old Oct 18, 2005 | 06:01 PM
blind527's Avatar
He won't pass a sniffer test unless your cats are hot with the AIR off. The AIR just helps the cats heat up in the first 3 minutes. If you have cats, just get the cats hot before you go in for the sniffer test if there is one.
Old Oct 18, 2005 | 06:05 PM
OBE1 95Z28's Avatar
Without the A.I.R. system you run the risk of destroying your cat(s) prematurely from the rich fuel mixture during open loop start-up (first 2 minutes of driving). Usually people that delete the A.I.R. system also delete their cat(s).
Old Oct 18, 2005 | 06:53 PM
sabre81's Avatar
i have no sniffer test here in ny for my 94. Ill probably delete my cat anyway.
Thanks!
alex5366
Feb 17, 2015 10:43 PM
Chris Anderson
Jan 27, 2015 08:30 AM
Jul 4, 2005 05:00 PM
