A.I.R. Pump Connectors??????
Old Jul 22, 2008 | 09:01 AM
96z28t56's Avatar
I keep having trouble with my AIR pump. I replaced it with a different one, but it seams to be a different design. The one that was originally on my car has a harness stemming out from the connector that connects to a bleed valve above the pump, while the one that I just got has the wires going directly into the pump from the connector. Its is on a 96 Z BTW. I'm aware of the recall but I dont know if the two pumps are different because there is a OBD-1 or OBD-2 design, or what.
I just would like to know what the difference between the two is, and how i can go about getting the correct one, or if I can just rewire the one i have.
Thanks alot guys!
Old Jul 22, 2008 | 09:13 AM
multicar's Avatar
Either ebay or disassemble the original and clean it, oil it, and replace the valve seal rubber. Condensation creates muck inside the fan blade housing and will eventually lock up the internal fan. A good cleaning and it'll run like new again. There are previous posts on how to do this.
Old Jul 22, 2008 | 09:34 AM
96z28t56's Avatar
Thanks, i was just wondering what the difference between the two are,
One has a seperate harness comming from the connector, while the other, the wires go directly from the connector to the pump.
Does this have anything to do with the recall???
Old Jul 22, 2008 | 09:43 AM
multicar's Avatar
Don't know, never took mine in for the recall...didn't want some lame GM tech beating on my ride... I think Shoebox has a pic of the recall air pump and plumbing on his site.
Old Jul 22, 2008 | 12:23 PM
96z28t56's Avatar
Yea I looked at them, couldnt really determine anything that was included in the recall
Right now im just trying to clean my old pump, and i'll see how that turns out
Thanks alot
Old Jul 22, 2008 | 12:45 PM
camaro1fastz28's Avatar
i have one off a 96 that works fine pm if u need it
Old Jul 23, 2008 | 10:16 PM
The early (93-95) AIR system does not have the bleed solenoid, so there's no need for the extra wires on the pump. The pumps should be identical, except for the wiring. The 93 pump was mounted to the chassis, rather than the front of the engine, so that might provide some physical difference. But it appears you have a pump off a 94 or 95, without the wiring for the bleed.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
rick350
Mar 14, 2015 10:46 PM
Jul 4, 2005 05:00 PM
