i pulled the intake and replaced the gasket but now my oil guage dont work
Old Jun 1, 2009 | 03:22 AM
grimjeeper73's Avatar
i replaced the intake gaskets but when i started it the oil pressure gauge went all the way to the left past 80 and wont come back down even when the key is off it just stays there all the time help
Old Jun 1, 2009 | 05:14 AM
The oil pressure sensor is on the back/top of the block, right behind the edge of the intake manifold. You either knocked the wire off, or damaged the sensor.
Courtesy of Shoebox:
http://shbox.com/1/oil_pressure_sensor.jpg
Old Jun 1, 2009 | 08:27 AM
mzgp5x's Avatar
My experience... They break easy. Also, they do not work very accurate. A cheap sensor with bad cal. But, I think it qualifies as an idiot light. B.
Old Jun 1, 2009 | 03:52 PM
lr383's Avatar
Same thing happen to me last week ended being broken wire at the senser just check the wire by grounding it, the gauge should come back down if it is ok If it is the plug just buy new pigtail. EFI CONNECTION has them $10
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
smokin25th
Jan 1, 2015 09:06 AM
Jazsun
Dec 29, 2014 12:14 PM
Jul 4, 2005 05:00 PM
