I need some help, sputtering LT1 undering @ 1500 RPMS
I have a 1996 Trans am and just recently it started sputtering badly under acceleration, mostley if @ 1500 rpms. After 2,000 it begins to gain power quickly though. I recently changed the spark plugs and wires and had to remove and reattach a header to do so. Also its been pretty warm here in L.A (around 90) just in case this might attribute to the problem. I already added a fuel injector cleaner to the gas tank but it doesn't seem to be helping and I'm going to clean the throttle body, any other ideas?
From: Knoxville, Tennessee/Mooresville, N.C./Phoenix, AZ/Bristol, TN
Does it "sputter" when cold as well? or just after it has reached operating temperature?
There's no harm in double-checking all the plugs are in good and tight, as well as making sure the plug boots are seated properly(or if a wire had been burned). Cleaning the throttle body might help, but I have a feeling it won't for this situation.
Alex Barnes
Jan 24, 2015 10:21 PM
edman
Jan 22, 2015 02:45 PM
