I need some help with my speedo and fuel gauge
Banned FOR SCAMMING - Nick[William] Dascal - (516) 931-0586
Ok, I just installed the ebay reverse glow gauges. It works great and all but im not too sure that the fuel gauge works(the stock one) because before I did this mod if was at 1/4 tank and now it says a little less than 1/2. And the speedo is just dead, its at dead bottom where the stopper pin is. and it dosent move when i drive it.
Did i mess up the needles or sumthing?
What do you reccomend I do?
You need to make sure when you put the new gauge face in that the needles are not touching the face. They cannot touch even the slightest bit or else they will stick. If they are touching during any part of their movement, you will need to use two sided tape or a little glue if you prefer to prevent the face from bubbling up and touching the needles.
Garcia5
07-07-2022 06:51 PM
99TransAmWS6
02-12-2015 07:23 PM
07-04-2005 05:00 PM
