I need to know what these DTC's mean
Old May 20, 2007 | 02:31 PM
eagleknight97's Avatar
Tried using Shoeboxs site but the DTC portion must be down or something because it wasnt coming up for me.
P0134
P0135
P0160-twice
P0400-twice
Old May 20, 2007 | 02:34 PM
2000GTP's Avatar
His site was working fine for me:
P0134: Heated Oxygen Sensor (HO2S) insufficient signal activity Bank 1 Sensor 1 Sensor 2 = after cat
P0135: Heated Oxygen Sensor (HO2S) heater circuit Bank 1 Sensor 1
P0160: Heated Oxygen Sensor (HO2S) insufficient signal activity Bank 2 Sensor 2
P0400: Exhaust Gas Recirculation (EGR) system
Old May 20, 2007 | 02:40 PM
Ah, just doesnt seem to work with Firefox. It works fine for me on IE now that you said that it was working for you.
So what then do those mean exactly. I just put in Headers with no cats, so the after cat code, the P0160 I can see but what do the other ones mean?
Old May 20, 2007 | 02:42 PM
2000GTP's Avatar
That would make sense, I just so happen to be using IE.
Old May 20, 2007 | 08:25 PM
P0400 is most likely due to the headers. Headers/no cats reduce back pressure in the exhaust system, and reduces the EGR flow to the point where the PCM diagnostic can not detect it.
P0134 detects an open circuit to the O2 sensor. Wiring problem most likely. P0135 detects a faulty O2 sensor heater circuit. Also most likely a wiring problem. Did you use an extension? If so, look there.
Old May 20, 2007 | 11:33 PM
Nope, no extensions. Stock wiring on everything. Would any of those codes cause any driveability issues or anything worse than just throwing a code?
How can I keep the EGR system but get rid of the P0400 code? I know EGR is kind of a good thing to have and its not really cluttering anything up, you cant even see it. I suppose thats also part of the reason i dont want to remove it...I cant see it.
Also, why dont I have an AIR code? I took the AIR system out of my car, so why no code for it?
Old May 21, 2007 | 11:49 AM
An open circuit on an O2 sensor prevents the PCM from going into closed loop. In effect, your PCM can no longer "learn" to compensate for modifications.
I've heard of a technical service bulletin and a "low backpressure EGR valve", but I don't know much more than that.
Good question. There are several codes for the AIR system, since the PCM checks both the electrical circuit to the pump and cycles the pump while looking at the O2 sensors for significant changes to the O2 readings.
KYWes
Sep 26, 2015 08:49 AM
MDZ28
11
Sep 24, 2015 09:15 AM
tommalcolm
Sep 11, 2015 03:39 PM
MDZ28
Sep 7, 2015 09:16 PM
4586
Aug 24, 2015 11:04 PM
