I need help!!! Gears, PCM, Engine Rev
Old Jun 27, 2008 | 11:41 AM
bkpliskin's Avatar
ok, so you can see my mods in my sig....I recently had the 3.73's installed and the PCM tune was only done by a Hypertech Power Programmer. Pretty simple stuff. Well, since I installed the programming software and the 3.73's....my car seems to be driving quite a bit slower than it did when I had 2.73's. Once I hit 70mph the car is the slowest piece of **** on the face of the earth. I used to be able to fly from 70-140....now it takes me forever just to get from 70-100.
Should I raise my rev limiter and then raise my shift points so I'm in the power band a little better. Or is this just the horrible horrible downside of going to 3.73's?
from 70-90mph used to be second gear which would be 1.67x2.73...and now from 70/75-90 I'm in third giving me a 1.00x3.73 drive ratio? Is this pretty much the only reason? Is there anything I can do with my PCM and shift points to maybe get the engine into the power band a little more?
Old Jun 27, 2008 | 12:05 PM
bombebomb's Avatar
Hypertech progrmmar is a no no. I would almsot bet its the programmar.
TobyZ28's Avatar
Throw away hypertech and get a tune from one of the tuners on the board
Old Jun 27, 2008 | 12:15 PM
bkpliskin's Avatar
do you guys think if I reverted it back to stock (the pcm) with the exception of the speedo calibration that I'd notice a better result...
Also, why would the programmer slow the car down? If they manufactured these to increase power output, how could they decrease output? I mean, I know the hypertech programmers aren't that great, but how could they hurt the car in any way?
Old Jun 27, 2008 | 12:19 PM
TobyZ28's Avatar
Probably not.
I'm guessing your shift points are happening too early making the car feel like a slug, I cant imagine hypertech knowing how to properly do the shift points. Its only good for speedo calibrations and such.
PCLZ28
Dec 24, 2015 05:19 PM
willismoons
Feb 14, 2015 08:42 PM
Alex Barnes
Jan 24, 2015 10:21 PM
Jul 4, 2005 05:00 PM
TheV6Bird
11
Jul 28, 2002 05:25 PM
