I need help choosing spark plugs
Old Nov 24, 2005 | 10:31 AM
89385formula's Avatar
My new engine is just about finished, so I am trying to get everything I will need to get it together and installed in the car. I need help choosing a Spark plug brand and plug. The car is will run NA til the bugs are worked out and final NA tuning is done, however I have an 75-150 nitrous kit on the car as well. I want a plug that I can use for both if possible. Its a 355 w/ 11.7 compression ratio, worked LT1 castings, ported LT1 intake, full bolt ons, E/WP, Mallory 685 ignition, MSD coil. What would you recomend?
Old Nov 24, 2005 | 10:51 AM
LUDA0840's Avatar
Re: I need help choosing spark plugs
autolites 103's or the NGK iridium spark plugs.
Old Nov 24, 2005 | 11:47 AM
blackztpi's Avatar
ngk tr6's are good for high compression and especially boosted or sprayed motors.
Old Nov 24, 2005 | 12:11 PM
BlackDog's Avatar
AC Delco rapid fire. Take a look - http://www.acdelco.com/html/pi_plugs_rap_main.htm
Here's a write up from Wards autoworld - http://waw.wardsauto.com/ar/auto_gm_launches_new_3/
Old Nov 24, 2005 | 05:02 PM
1racerdude's Avatar
American made and no exotic metal in them.
Old Nov 24, 2005 | 05:44 PM
96ZCamaro's Avatar
I went with the ngk iridiums on my car and am happy with them.
Old Nov 24, 2005 | 06:38 PM
So you recomend those Rapid fires then? What number.
Old Nov 25, 2005 | 07:04 AM
BlackDog's Avatar
RF14
Old Nov 25, 2005 | 07:34 AM
kick Z tail out's Avatar
AC Delco? haha... hahaha.
Old Nov 25, 2005 | 08:41 AM
jkipp84's Avatar
I'd do a search on those rapid fires and get a couple of other opinions... Personally, I'd never put another set in my LT1 (or any other engine for that matter).
Darth_tsunami
V6 Tech
Sep 18, 2015 01:57 AM
markzzzz
May 8, 2015 09:21 AM
blkWidow
May 3, 2015 08:42 AM
nikko
Apr 20, 2015 07:56 AM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
