I Need Help Asap!!!!
Old Sep 29, 2003 | 12:42 PM
playaz28's Avatar
Angry I Need Help Asap!!!!
I was working on getting the crank hub on my car, another post i made described it, and it was going on crooked. so my dumbarse decides to put a little more force into it to see if maybe i could force it on straight. NOPE! I ended up breakin the bolt off in the crank, flush I might add, and now I'm stuck.
I don't know what to do. My uncle said I can try to use and EZ out to get it out, I don't think that would work. What else can I do or what should I do? Should I look at just replacing the crank itself or maybe do a 355 buildup.
I don't have a lot of cash, I can maybe get $3000 scrounged up for this. The car's a '97 Z, A4, stock lower end. And one really pissed off owner.
If anybody can help out, give ideas and/or suggestions that would be great.
And yes I know, now is the time for the 355/383/396 build up, but please keep in mind that I don't have a lot of money at my disposal.
Phil
Old Sep 29, 2003 | 12:53 PM
turbo_Z's Avatar
EZ out is the only solution unless you drill out the bolt and retap the crank.
Old Sep 29, 2003 | 12:58 PM
playaz28's Avatar
What kind of work would that include? I know I have to drill a pilot hole in the bolt, I guess what I really mean to ask is - will it work? If the crank bolt is in there as stuck as I think it is, will i need any kind of lube on the bolt? Also, I think I would need to get an angle drill because the room I have to work with. I haven't taken the radiator's out, I can if I have to. At this point I don't really care what I need to do as long as I can fix my car. Which I may not want to do since I broke the damn thing, lol.
Thanks for the quick reply!
Old Sep 29, 2003 | 01:01 PM
joeSS97's Avatar
Heres a trick that might work.Take a small ,SHARP punch and tap on the outer edge of the bolt in the loosening direction.If that doent work,I would try a left handed drill.It may loosen it.Or drill it out with the left handed drill,then use an easy out.One of these should work for you.
Old Sep 29, 2003 | 01:05 PM
S.J.S.'s Avatar
I wouldn't drill it out....but if you do make sure its even or you might throw off the balance on the crank.
Old Sep 29, 2003 | 01:11 PM
BUBBA's Avatar
Visit your local tool rental place and get the tools needed incl easy outs, drill bits, drill. Once you can get a piece of it with some vice grips, you should be good to go.JMHO
Old Sep 29, 2003 | 01:15 PM
BUBBA's Avatar
Also, as mentioned. If you have a chisel that will allow you to do a bit of hammering on the bolt end to back it out enough for the vise grips, that's always been a productive method for me. Don't beat the heck of it, just gently and accurately use the chisel to back the bolt out to (counter-clockwise,of course).
Old Sep 29, 2003 | 01:39 PM
playaz28's Avatar
thanks guys, I will try that idea on drilling it out. I just gotta get an air compressor so I can get the hub off. Trying it by hand is not a good idea right now since I will probably break my damn wrenches, it seems to be stuck or that bolt is still holding it on?
Devinfoote87
Sep 4, 2015 05:52 PM
asilomar244
Jul 12, 2015 05:53 AM
james4154
Jun 15, 2015 12:16 PM
PublicEnemy1
Apr 7, 2015 12:21 PM
