i know its wrong but i want the bottle
Old Sep 8, 2004 | 11:29 PM
Jonsz28eatsford's Avatar
alright guys.....i need some advice on the juice, if im planning on running a 75hp dry shot do i need to mod my valves and such?? or should i be good bolt and go?
Old Sep 9, 2004 | 01:17 AM
IDAREU's Avatar
Re: i know its wrong but i want the bottle
There's nothing wrong with the bottle Is your car bone stock? or modified? The only thing necessary is a tune up with 1 step colder plugs. Make sure you're fuel filter is relatively new and that the pump is supplying good pressure. It would be nice to up the injectors since its a dry shot. I don't know what the kit you're planning on running includes but I always recommend a fuel pressure safety switch. Knock retard at the low of a hp level is debatable. I ran a 125 wet with no retard and pump 92 and didnt have any problems but I kept a close eye on detonation. But mainly keep the tune fresh and the car should be fine.
Old Sep 9, 2004 | 02:03 AM
Hood_Lum's Avatar
You should be able to just bolt it on and go.
Change out the platinum plugs if you have them.
I've been using a 150 shot dry with no retard.
Old Sep 9, 2004 | 07:18 AM
'94 Bad A Z28's Avatar
150 shot here.... wet... all day on a stock car with a stock tune.
Before the h/c.... when the h/c is done it will still have a 150 shot on it, just have to worry about the tranny a little more. hah
With my NX 150 shot (with far below their recommended bottle pressure) my car dropped 1.4 seconds and trapped 16mph higher in the 1/4.
Old Sep 9, 2004 | 07:46 AM
chrism400's Avatar
Look at what just a 50 shot dry does for me! Half of the reason is the fact that I ran it with the stock converter and it helped me get out of the hole a bunch.
Old Sep 9, 2004 | 08:06 AM
Im sorry, but there is no way that a 50 shot, not even a NX 50 shot, gained you 8mph and dropped you almost a full second. I just can't believe that.... it's prolly a 75 shot.
Old Sep 9, 2004 | 08:09 AM
WOT's Avatar
WOT
I understand what you mean. It's easy to want to go back to the bottle...but you must be a man and stick to cups. You might try a sipper cup if you find the transition difficult.
The one thing to keep in mind when thinking a the bottle is cheaper are reoccuring refill costs. Researching things and just plain being not stupid will go a long ways to being safe with N20.
Old Sep 9, 2004 | 08:19 AM
WS Sick's Avatar
If he purges and shoots off the line you'd be surprised.
I ran a 125 wet shot on a bolt on car with a cc305 cam and 3.73 rear gears and vigilantee and ran a best of 11.73 @ 116.85 mph. Without purging I allways only ran 12.20s on the same set-up, but after I added a purge solonoid and hit it off the line it imroved things significantly. I still want to put the juice on my 383.
Old Sep 9, 2004 | 08:26 AM
Actually yeah, I can see that, I have never purged my system before running, or had the correct amount of bottle pressure. Because I didn't have and still donty have a purge and I haven't put in my bottle heater yet.
Old Sep 9, 2004 | 08:28 AM
WS Sick's Avatar
You'll see a massive gain purging the system and having proper bottle pressure.
Old Sep 9, 2004 | 08:29 AM
Yeah but I wont notice it that much because I'll have the gain of the heads and cam as well, haha.
Old Sep 9, 2004 | 11:42 AM
chrism400's Avatar
If I plug in the numbers on Drag 2000, it says that I am netting about 55 hp to the wheels from the 50 shot. I do purge, and I do hit it right after hook-up. My 1/8 th mile time is 7.91, 60 foot was 1.73. I backed up the 12.25 with a 12.33 @ 111 the same night. Bottle pressure was just a hair over 1000 lbs. I have no reason to lie about this. Believe me, I was shocked at the improvement. This same nitrous set up was on my 1996 Neon which ran a 14.86 @ 93 with a turbo muffler and asp underdrive. The Neon ran 16.88 before the bottle. The stuff works - it's immediate torque. Like I said in an earlier post, the dramatic change was basically in the launch.
Aaront810
Aug 29, 2020 09:34 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
fift5
11
Oct 1, 2015 10:31 AM
95craz28
11
Sep 12, 2015 07:47 AM
Aaront810
Sep 11, 2015 11:24 AM
