I know the answer is probably no but..
Old Apr 13, 2005 | 07:52 PM
speed_demon24's Avatar
Can I use the stock injectors if I'm putting out 380+rwhp? I'm thinkin about switching the gm 846 cam (222/230) and I would like to keep the stock injectors if I could but I'm guessing I can't. If I can't, would the racetronix 28lb or 32lb be a better choice for me?
Old Apr 13, 2005 | 07:54 PM
unvc92camarors's Avatar
Re: I know the answer is probably no but..
yea, a "general" rule i think is that the stock ones are usually good til about 400rwhp
Old Apr 13, 2005 | 08:06 PM
jchevy's Avatar
I dont think an 846 cam will put you at 380+rwhp
What duty cycle are your injectors at now?
Old Apr 13, 2005 | 08:25 PM
I'm probably at 360 RWHP+ (put out 352 with 12.0 a/f, 48mm throttle body, and my pre-load adjusted too tight on my comp R's) with the 210/224 so I think 380rwhp would be a piece of cake. I haven't had a chance to see my injector duty, does anyone have the forumla to calculate it from the injector pulse width?
Old Apr 13, 2005 | 08:31 PM
jchevy's Avatar
Try to get a reading on the duty cycle, i have always been told you dont want them above 85%.
You are probably aproaching that now with your stock injectors and your current setup.
Old Apr 13, 2005 | 08:49 PM
All my scanmaster reads is the injector pulse width in miliseconds though, how do I convert that into duty %?
Old Apr 13, 2005 | 08:50 PM
97bowtie's Avatar
I have to second that you won't hit 380 rwhp w/that cam. Even if you are at 360 rwhp now, you'd be doing good to pick up 10 rwhp w/the cam swap. Something like a GM847/CC306 would give you a better shot at 380 rwhp (depending on how good your heads are).
As jchevy stated, 85% duty cycle is a pretty safe number. You are probably right around there now and w/ a bigger cam/more power, you will likely be past 85%. I've seen guys run 90-95% duty cycle, but it's not a good idea.
Get the car scanned.
Old Apr 13, 2005 | 08:52 PM
97bowtie's Avatar
Duty Cycle % = (Pulse Width * RPM)/1200
Old Apr 14, 2005 | 09:46 PM
Well I went ahead and ordered the racetronix 32lb injectors, I figured I shouldn't chance it with the stockers...
Old Apr 15, 2005 | 12:36 AM
Z95m6's Avatar
I'll say i also don't think you'll make 380. You basically are running a CC305 and i dont' think anyone has put down that kind of power with just ported stock LT1 heads. I do think you made a good decision with going with bigger injectors though.
Old Apr 15, 2005 | 12:31 PM
I'm going to try to prove everyone wronge.
Daluchman1974
Sep 11, 2015 06:12 AM
cmsmith
Aug 9, 2015 07:30 PM
michaelzilinski
Jul 31, 2015 08:41 AM
NewsBot
Jul 29, 2015 08:10 PM
Latronaxe
Jul 20, 2015 12:00 PM
