i have an intake backfire and exhaust backfire ....what causes this ?
Old Mar 22, 2010 | 11:48 AM
tsnlarue's Avatar
it runs ....and when you give it the gas it will pop in the intake and it will pop a couple of times out of the exhaust .....any ideas what thiis could be?
Old Mar 22, 2010 | 12:49 PM
Revolutionary's Avatar
bent valves, intake gasket leak, timing problems...
Old Mar 22, 2010 | 01:38 PM
tsnlarue's Avatar
what gasket leak would that be ..head gasket and i have a opti spark how can it be out of time?
Old Mar 22, 2010 | 02:49 PM
97WS6SCharged's Avatar
More info on your setup would be useful. Could be one (or more) of many causes.
Old Mar 22, 2010 | 03:02 PM
slingshot's Avatar
If you have a 96-97 lt1, then the pin could be in one of the wrong holes...if you have a 93-95 and it does not go on properly, the pin is splined so it could be over one spline. My brother managed to do it on my car somehow, I have never screwed up the installation myself. You could also have a loose timing chain leaving it jumping timing when it runs..which could seriously screw up some stuff such as valves hitting pistons.
Old Mar 22, 2010 | 03:03 PM
bw_hunter's Avatar
It really sounds like the valve timing is the issue but we can't really tell from you description. Valve timing issues come from a severely stretched timing chain.
These cars make all sorts of noises but the backfiring in the intake is a big issue. Do a compression test first....low compression is one symptom of valve timing issues.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
MadMav
Feb 6, 2015 11:02 PM
markaubuchon
3rd Gen / L98 Engine Tech
Jan 14, 2015 01:48 AM
slothgrant
Aug 22, 2002 03:01 PM
