i have the headers and y pipe what else do i need???
Old Oct 22, 2006 | 09:54 PM
jamilz28's Avatar
i have the headers and y pipe what else do i need to do an header install???
Old Oct 22, 2006 | 09:56 PM
JasonK94Z's Avatar
Re: i have the headers and y pipe what else do i need???
Gaskets? Header bolts? Mechanix gloves to save your knuckles.
Old Oct 22, 2006 | 10:00 PM
jamilz28's Avatar
is that it? i thought that i need o2 extenders or something like that.
Old Oct 22, 2006 | 10:02 PM
Daniel6718's Avatar
panhard rod? that i never recieved?
Old Oct 22, 2006 | 10:04 PM
MeanGreen97Z's Avatar
If they are long tubes you need extensions and o2 simulators. Do yours have EGR and AIR fittings?
Old Oct 22, 2006 | 10:06 PM
jamilz28's Avatar
yea
Old Oct 22, 2006 | 10:13 PM
95LT1conv's Avatar
only need 1 extension for the pass. side. dont think you'll need sims since it is a 94
Old Oct 22, 2006 | 10:14 PM
True... I didnt look at the fact it was a 94... maybe some OTVC wires and new plugs then.
Old Oct 23, 2006 | 01:37 PM
2000GTP's Avatar
Yeah, no o2 simulators since its a 94, it has no post-cat o2 sensors. I second the idea of the over-the-valve cover wire setup. You will save your wires and potential headaches by doing that versus the stock routing. As for the 02 extensions, definitely for the passenger side. The drivers side you could probably get away with, but it is still a good idea because it will give you some extra slack and you can route the harness better to keep it away from hot spots. I would go with the 12" extensions.
Old Oct 27, 2006 | 11:52 PM
jamilz28's Avatar
what size bolts to get or what kind
Old Oct 28, 2006 | 02:03 AM
2000GTP's Avatar
I would get the 1" long bolts and anything that locks such as the Stage 8s or Breslins.
Old Oct 28, 2006 | 11:30 AM
jamilz28's Avatar
just 1 inch so any 1 inch header bolts will work?
Old Oct 28, 2006 | 03:15 PM
hulettsz28's Avatar
make sure you have gaskets, 02 extensions, some sleeves or otvc wires, header bolts...etc.
Old Oct 29, 2006 | 07:59 AM
curly's Avatar
Don't forget a jack and jackstands (if you don't have access to a lift). The higher you can get your car off the ground, the easier it will be to slide the LT's in from the bottom.
Old Oct 29, 2006 | 09:38 AM
jamilz28's Avatar
i have suv-truck jacks they are tall as hell
TitoPR221
May 26, 2015 12:20 AM
95z_28_camaro_4_Ivan
May 8, 2015 09:56 AM
Russ95Z28
Apr 23, 2015 01:55 PM
Queens94z28
Mar 23, 2015 08:06 AM
alphaauto
Jan 23, 2015 07:42 AM
