i have the headers and y pipe what else do i need???
Re: i have the headers and y pipe what else do i need???
Yeah, no o2 simulators since its a 94, it has no post-cat o2 sensors. I second the idea of the over-the-valve cover wire setup. You will save your wires and potential headaches by doing that versus the stock routing. As for the 02 extensions, definitely for the passenger side. The drivers side you could probably get away with, but it is still a good idea because it will give you some extra slack and you can route the harness better to keep it away from hot spots. I would go with the 12" extensions.
