I got a big problem....
Old Jul 15, 2003 | 05:37 PM
meangreen94z's Avatar
Angry I got a big problem....
My cousin recently bought a '95 trans am (5.7 A4) and we went out to drive it and it has no *****. It shifts from 1st-2nd but wont shift from 2-3. It only revs out to about 3,000 RPMs in 2nd and wont shift. The gas pedal is all hard and not smooth and it just doesnt seem like it has any power. Anyone ever have this problem? Need some help!!
Old Jul 15, 2003 | 05:41 PM
ZR1 camaro's Avatar
does the throttle open all the way, mabey somthing is binding up with the cable and your not getting full throttle. Just a thought.
Old Jul 15, 2003 | 09:12 PM
ttt, got to look tomm.
Old Jul 15, 2003 | 09:21 PM
rage366's Avatar
shifts from 1st to 2nd and then nothin? it doesnt shift into 3rd? or OD? has the tranny been replaced ?
Old Jul 15, 2003 | 09:25 PM
IrocManiac's Avatar
Could have a stuck valve...a thoroughly clogged cat...I kind think the throttle cable Idea seems to be the most logical though...could also be the pcm.
Old Jul 15, 2003 | 09:29 PM
rage366's Avatar
Re: I got a big problem....
it never goes above 3000? or it doesnt go above 3000 in 2nd?
Old Jul 16, 2003 | 12:04 PM
In D, it will shift from 1st to 2nd fine and then when its in 2nd, it will only rev to 3,000 rpms and will not shift (with the pedal all the way down).
Old Jul 17, 2003 | 10:27 PM
95 TransAmMan's Avatar
Trans Am problem
This could actually be a throttle problem, the same thing happened to my car
Old Jul 17, 2003 | 10:38 PM
rage366's Avatar
Re: Trans Am problem
i agree...because it wouldnt make sense if the tb cable works fine in only certain shifts...if it didnt work, it wouldnt work in any gear...
hmm, could it be an injector problem?
Old Jul 17, 2003 | 11:18 PM
Transamdriver's Avatar
No SES light?
Old Jul 18, 2003 | 12:56 PM
How many miles are on the car?
Old Jul 18, 2003 | 01:22 PM
Sweetred95ta's Avatar
My car has the shifting problem. It shifts fine from 1-2, but it will get stuck in 2nd and not shift to third. I just had my tranny rebuilt. I dont know if it would be the throttle cable cuz if you can pull enough rpms to shift into 2, then you should pull enough to shift into third. I know my car shifts into 3 before 3000 rpm if im not into hard. You might want to check the TPS, the tranny could need to be rebuilt, or someone screwed your shift points up by tuning it wrong.
Old Jul 19, 2003 | 01:26 PM
Keep us updated when you find the problem, because i am curious what it is.
Old Jul 19, 2003 | 01:37 PM
rage366's Avatar
my tranny was rebuilt recently...very BADLY...the bastard who rebuilt it had screwed it up, because it would start in 2nd gear, and then shift to 3rd gear, and THAT'S IT!! it wouldnt go into first or OD...
i took it to another tranny shop, and they told me that it was an electric problem due to an improper rebuilt...they said that some parts had installed backwards, and some wires crossed...blah-blah-blah...
my advice, take it to another tranny shop...
bunker
Jan 30, 2016 08:09 PM
Sep 18, 2015 03:46 PM
NewsBot
Aug 3, 2015 02:40 PM
Louey
Pacific
Jul 27, 2015 09:58 PM
Boss002
Jul 9, 2015 03:33 PM
