i feel like i might sound dumb
Old Feb 21, 2007 | 08:25 PM
93camarochrisz28's Avatar
will a 95 corvet motor work in a 93 camaro as a drop in thing ??
Old Feb 21, 2007 | 09:42 PM
seawolf06's Avatar
I know that 93 is a speed density tune, so as long as you don't use the MAF from the 95, that should be ok. The 93 injectors were also smaller, so you might have to get it tuned, might not. Safest bet is to get the 95 pcm, wiring, injectors and MAF system and use all of that.
Old Feb 22, 2007 | 01:01 PM
69gto96z's Avatar
I think the vette motors have the accesories(a/c compressor, power steering) mounted in different locations. But I am not 100% sure on that.
Old Feb 22, 2007 | 01:07 PM
Basically, if you take everything that is different on your 1993 and use it on the 95 engine it will "drop in".
Old Feb 22, 2007 | 01:11 PM
ok cool that is what i was hoping would happen i am just getting the block and heads and intake that is it
Old Feb 22, 2007 | 01:18 PM
Javier97Z28's Avatar
Moderator
You will have to swap intakes.
Old Feb 22, 2007 | 01:23 PM
will the acc all fit on right fron my car to that motor ??
Old Feb 22, 2007 | 01:56 PM
Moderator
Bolt hole locations for accessory brackets, etc, will be the same on both blocks/heads.. no problems there.
Old Feb 22, 2007 | 02:02 PM
cool does it have the same cam and all that or is it a better on ?
Old Feb 22, 2007 | 04:02 PM
seawolf06's Avatar
Same internals, just has 4-bolt mains instead of 2-bolt.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
blkWidow
Apr 21, 2015 01:56 PM
Apr 16, 2015 09:57 AM
karnykamaro
Feb 2, 2015 01:37 PM
