I couldn't solve my Knock Retard problem, so...
should I disable the knock sensor? I have desensitized KM, but when I rev the car (while driving) I see 3-4-5-6 degree KR. (Even I have desensitized!!!)
Re: I couldn't solve my Knock Retard problem, so...
im having the exact same problem hopefully someone can figure this out but i hope it was just a bad knock sensor but once i get my car done ill data log it and let you how it went if its still there i might all together eliminate the sensor
mine are disabled. Have had no problems. Even on my last program from Bryan Herter he had them diabled above 2000 rpms. If you stay N/A you should be ok. With boost or Nitrous you will probably need them.
HVY SS
HVY SS
Magenta_Hearts
Mar 25, 2015 10:24 AM
