I can't take it anymore! (surging!!!)
Re: I can't take it anymore! (surging!!!)
Originally Posted by 1racerdude
I have a 260ish on a 108+4 on pump gas on the street with ,4L60E and stall with 4.10's. What's wrong with a 240ish cam.
Get it tuned and checked for problems and get the drive ability tuned.
Yea it shakes the antenna.
Originally Posted by Javier97Z28
How do you "know" it's not the tune... my LE3 is in the higher 23x range, and it surges a little with the mail order tune, but its perfectly driveable around town.
Originally Posted by Kevin Blown 95 TA
JustNo, what's your compression? Do you have the stock & correct PCV system?
Originally Posted by Heatmaker
Not surprised to hear about the SPEC, is the clutch chatter apart of the problem too? My old stage 3 was like lhell under 2000rpms... I had to constantly keep it above 2K to keep the car from bucking. The car would just keep lunging forward it was crazy... IT was like I had a giant cam or something and this was on my stock cam. I could barely get around the Supermarket parkinglot. boy did I hate those times. You should try the Ram PowerGrip HD. That clutch is excellent and holds up extremely well.
Going with M6 should be fan to drive
I had 2 stage 2's from Spec, and aStage 3, and all clutches failed within 1000miles of installation, and on the stage 3 the springs broke. I always had problems with them disengaging. They all disengaged down low no mater what I did. new hydraulic kit, adjustable master and all, I then tried a Mcleod (non Street twin), but I was making to much power for it, and then finally I went with the Ram Power Grip HD, so far the clutch disk has outlasted the pressure plate, and it bites strong 30K later. I don't remember there being any chatter... the car bites down hard though if your not careful. good luck though.
I had 2 stage 2's from Spec, and aStage 3, and all clutches failed within 1000miles of installation, and on the stage 3 the springs broke. I tried a Mcleod (non Street twin), but I was making to much power for it, and then finally I went with the Ram Power Grip HD, so far the clutch disk has outlasted the pressure plate, and it bites strong 30K later. I don't remember there being any chatter... the car bits down hard though if your not careful. good luck though.
For example I can't use the MC Leod ST with the Spec Alum. Flywheel.
you can use it with the spec flywheel. I used it with a Fidanza flywheel, and now I'm now using it with the stock flywheel. It's designed like a standard clutch.
Spec Stg 3+ can be better, but I don't want to test the Spec Series.
There's a few threads on here about spec.. I'm sure I worte a bunch of them myself, but I gave up on spec, when I was going close to 90 and had the springs go out on me in the middle of a race, and the thing was I was making no way near the power I am now.
35-98516HD Ram Clutches Powergrip HD Clutch Set (includes disk, pressure plate, throw-out bearing), 1993-1997 LT1 F-body
4.10's and get her on the dyno tuning it - and you'll be fine -
my 230/236 112 was hell to drive at first. then got ion's tune and it solve a majority of the surging, but still would be real bad under 2k- got to the point of me avoiding parking lots or traffic. then i blew my rearend and threw set of 4.10's in there, and couldnt believe how much that helped eliminate the problem.
on dyno had bit more tuning done to tweak it, and you can barely tell shes got a cam in her.
unless your planning on WOT on highway runs i wouldnt worry about it-
me shifting at 6.5k ive hit about 145 in 5th
to give better idea- heres a crappy vid my friend shot-
http://media.putfile.com/revving-to-6500-whine
started in 1st- end of 3rd im a little over 105
I didn't get something. The end of 3rd is 105, but the end of 5th is 145?
Where is 4th ?
i wanna say its around 130- ill videotape her from a dig today, and use my DV camera to be able to clearly see the gauges. but .... i believe
1st = 50ish
2nd = 70ish
3rd = 105ish
4th = 130ish
5th = 145-150ish
i could be way off with the times over 100 - since putting the gears in ive only taken her over 100 a couple times, and only went wide open once with a buddy. thats how i know she does 145ish in 5th but wasnt really paying attention to the speedo. Shiftlight was letting me know
1st = 50ish
2nd = 70ish
3rd = 105ish
4th = 130ish
5th = 145-150ish
ha... ummm. ...
stock
but trust me it aint lasting to long. was in the city for a while with the car, and spent a while in boston, 10 min in traffic and clutch would start slipping and chattering real bad.
right now im in middle of nowhere, so it aint bad to deal with, but it needs to be replaced.
stock
