i cant even bypass my tb!!!!
Old Apr 26, 2006 | 11:52 AM
  #16
Jazsun's Avatar
Re: i cant even bypass my tb!!!!
W/ mu 93 I got a long screwdriver and pounded it w/ a hammer while taking plyers and bending the **** outa the clamp. Eventually got it. Took about 30 minutes.
Old May 11, 2006 | 06:09 PM
  #17
nodnarb481's Avatar
yes i did it!...
I cut the ****er up between the bend and the tb jawn. It looks kinda sketchy but it doesnt seem to be leaking at all.
I noticed that after i take my foot off the gas i coast a lot easier. Other then that my idle is a little more steady and thats all ive noticed.
While i was doing this i replaced my fuel filter and poured in some injector cleaning. This is the extent of the work (plus the elbow) that i have done since i got my car.
Old May 11, 2006 | 06:58 PM
  #18
JimboManJones's Avatar
Looking at www.shbox.com I was like, holy crap thats so easy, could probably take 5 minutes! I ended up removing the ps valve cover alternator, and alternator support and some vaccum lines, took a ridiculous amount of time for moving a hose.
Old May 11, 2006 | 07:02 PM
  #19
urbaNHunter44's Avatar
Yeah you haev to move the alt support, unplug a few plugs and move a couple vacuum lines. I then just cut the elbow with a knife and used pliars to wriggle the piece off the steam pipe. Then I bent the steam pipe up just a tad to make it easier to put the new hose on, then reassembled. Took 10-15 minutes.
Old May 11, 2006 | 07:52 PM
  #20
nodnarb481's Avatar
... what new hose?
Old May 11, 2006 | 08:20 PM
  #21
well, new to the steam pipe anyway. The hose from the other side of the TB I meant.
Old May 11, 2006 | 08:35 PM
  #22
nodnarb481's Avatar
oooo like of the two pipes you pull off the tb you are referring to the one on the left side (facing the engine) of the tb?
68camaroboltz
Oct 5, 2015 01:46 PM
colts0455
Oct 4, 2015 09:47 PM
football4life
Oct 4, 2015 07:48 AM
Rod Bender
25
Sep 16, 2015 01:47 PM
colts0455
Sep 2, 2015 12:41 PM
