I can tell you how to improve PERFORMANCE and GAS mileage IN HERE
OK I SOLD MY CLUTCH TO SOMEONE ON THE BOARD AND WE TALK FROM TIME TO TIME ABOUT CARS AND HE TELLS ME ALOT OF STUFF AND I LEARNED ALOT FROM HIM
NOW HERES WHAT TO DO GO TOGM PARTS DIRECT AND BUY A MAP SENSER IT FIXED A TONS OF STUFF ON MY CAR, REVS FASTER SMOOTHER AND I GET BETTER GAS MILEAGE AND THE PART ONLY COST $35 BUCKS AND 43 SHIPPED AND ITS SUPER EASY TO INSTALL U NEED A 8MM NUT DRIVER AND ITS IN, IN 2 MINUTES
ALSO ITS A GOOD THING TO REPLACE WHEN DOING A TUNE UP OR JUST FOR KICKS
AND FOR ALL YOU PEOPLE THAT HAVE SPRAYED THROTTLE BODY CLEANER IN YOUR INTAKE WHILE THE CAR WAS ON OR OFF UNLESS YOU DISCONNECTED THE SENSOR ITS BAD AND NEEDS TO BE REPLACED
can you give any more information? i have been getting bad gas milage lately and i KNOW the car used to get better, so this intrigues me sort off...can you give anymore symptoms of a bad map sensor?
TTT
TTT
You don't waste money on replacing sensors unless they are not working. A scan tool will easily tell you the condition of the MAP sensor. Yes, a bad one would effect gas mileage and power, since the purpose of the sensor is to detect engine load (vacuum).
Re: THROTTLE BODY CLEANER
[i]AND FOR ALL YOU PEOPLE THAT HAVE SPRAYED THROTTLE BODY CLEANER IN YOUR INTAKE WHILE THE CAR WAS ON OR OFF UNLESS YOU DISCONNECTED THE SENSOR ITS BAD AND NEEDS TO BE REPLACED [/B]
Have to disagree here. I 've used throtte body cleaner, MAP is working fine, and have checked it against a vacuum gauge. Still right on the money even after 150k.
bad gas milage is usually more affected by driving style and/or bad O2 sensors.
but yeah...the map is easy to change...and i bought one $35 from the local auto store last year.
90 percent of the time a bad MAP will give a major rich condition. You will be able to see black smoke at idle, and as others said it will trip a code. Do you have a SES light. Bad milage could be EGR, O2s, fouled plugs/wires. Just go have it scaned.
Re: I can tell you how to improve PERFORMANCE and GAS mileage IN HERE
