i am about to go insane and kill this car
Old Oct 10, 2005 | 08:12 AM
  #16
radik's Avatar
Re: i am about to go insane and kill this car
Just crimp your return line, then check.. lots of pressure good fp.
Old Oct 10, 2005 | 10:28 AM
  #17
89385formula's Avatar
Originally Posted by revtime
I see you have a walbro in your sig, how old is it? Have you ever replaced the regulator?
If your walbro pump is not that old and I am going to assume its not, then I would replace the regulator first.
Fuel pumps are tricky, sometimes they go out all at once and sometimes they slowly die over time. I had an 88 IROC back in the day that would start and run fine but was way down on power, turns out the pump was slowly dieing and putting out less and less pressure.
I really think its your regulator though.
His Walbro pump was installed approx. 1 week ago.
Old Oct 10, 2005 | 10:36 AM
  #18
Dave89IROC's Avatar
block the return line and see if the FP goes up, iof yes, regulator is bad, if no, probably the ling in the tank between the pump ang the top of the assm.
Old Oct 10, 2005 | 11:12 AM
  #19
snakethis69's Avatar
but no one thinks its the pump. i mean the pump sounds jsut like it always has.
Old Oct 10, 2005 | 02:38 PM
  #20
Dave89IROC's Avatar
it has happened, but more likely to be the line that hooks to the pump, pinch/block the return line and see what the fuel pressure does
USAirman93
Nov 24, 2014 03:37 PM
brandboZ28
Jan 31, 2003 06:19 PM
Zomie
Sep 2, 2002 09:01 PM
GC456
Aug 8, 2002 11:53 PM
regular Joe
Aug 8, 2002 03:47 PM
