Hypertech vs xbrand
Old Feb 24, 2003 | 12:04 AM
5H9D0W's Avatar
Hypertech vs xbrand
I guess you all know the hpp 160 thermostat connection.I bought an off brand instead of a hypertech and saved myself 15 bucks.Does anyone have problems w/ ther x brand or swears by(know something I don't)there hypertech thermostat.
Old Feb 24, 2003 | 12:07 AM
Got-LT1's Avatar
Shouldn't be any big differences IMO.
Old Feb 24, 2003 | 12:10 AM
Dr.Mudge's Avatar
I believe the Hypertech units are about $15 anyway, so long as your thermostat isn't a $4 SBC unit you should be fine. You can test it in a pot if you'd like, but I imagine it should work fine.
Old Feb 24, 2003 | 12:25 AM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
yea, you will be slightly slower due to the $15 in your pocket thats weighing you down.
more serioulsy,
every thing thing hypertech makes sucks ***.
Old Feb 24, 2003 | 12:30 AM
5H9D0W's Avatar
tramatised?
Old Feb 24, 2003 | 12:31 AM
WheelmanZ28's Avatar
The only thing good i can say about the Hypertech is u know ur getting the right Stat. I went to Murrays, asked them for a 94 LT1 Camaro Z28 160 degree Thermostat, the guy gave me one. I thought it looked wrong, but he swore on his grave it was the right one. I put it in, it seemed to fit strange. Sure enough, it WAS THE WRONG ONE! The 5 dollar AC Delco ones are the same damn thing, just make sure it's the right stat
Old Feb 24, 2003 | 12:34 AM
Yeah, hope you did not waste your money on the wrong one. It needs to be the long style thermostat to work properly in the reverse flow system (no matter who makes it).
LT1 thermostat
Old Feb 24, 2003 | 12:38 AM
5H9D0W's Avatar
s*#@,I'ts the small one,What does that mean.Why does it need to be long
Old Feb 24, 2003 | 01:03 AM
Because it is designed to work with the orifices in the water pump to direct the coolant coming from and going to the radiator. It is a much more complicated design than the old SBC style that fit in the intake manifold. If the short style is used, the in and out coolant can mix in the water pump and potential effiiciency will be lost.
Some people have managed to use the short ones and have said there were no problems. It may depend on the climate you operate in. IMO, I would not take a chance on using something that was not designed to work with the system. These engines don't take well to overheating problems.
Old Feb 24, 2003 | 02:18 AM
chesee48's Avatar
Just go and pick up a Hypertech. You'll save yourself all the hassle and worries =)
HarleyZ28
Oct 5, 2015 06:23 AM
colts0455
Sep 4, 2015 01:41 PM
colts0455
Jul 24, 2015 04:51 PM
thenewkid
Apr 12, 2015 07:42 PM
thenewkid
Nov 27, 2014 09:41 AM
