Hydra Rev - Does it work ?
Old Aug 14, 2003 | 05:04 AM
Van5150's Avatar
I know Hyrda Rev has been around for SBC's for a while now. I have not seen any info if they really work or are worth it. Anyone have any 1st hand experince ?
Old Aug 14, 2003 | 05:12 AM
frmula1's Avatar
From: Somewhere between a shotgun barrel, and a blood spatter on the wall.
what is it?
Old Aug 14, 2003 | 05:32 AM
dreamer1q's Avatar
Yes it works, and yes it is a good design. You lifters arent going to go anywhere.
Q
Old Aug 14, 2003 | 08:16 AM
ZZtop's Avatar
Where can I read about this? I have heard it mentioned before, but dont know what it is. Thanks.
Old Aug 14, 2003 | 08:18 AM
Fastbird93's Avatar
Would the hydra-rev keep the lifters firmly in the bores so that a cam swap without removing the intake would be possible?
Old Aug 14, 2003 | 08:19 AM
KCFormula's Avatar
I have heard only good things about the kit. The larger the cam a person is using the better things they seem to have to say about it. RPM probobly factors in there as well.
I am sold, I will be using it on my build.
Old Aug 14, 2003 | 08:41 AM
ZZtop's Avatar
but what is it???
Old Aug 14, 2003 | 09:26 AM
KCFormula's Avatar
http://www.airflowresearch.com/pages/hydra_rev.htm
Old Aug 14, 2003 | 09:38 AM
Chris'SS #2152's Avatar
No, it helps keeps pressure on the lifters in high rpm conditions.
Old Aug 14, 2003 | 10:52 AM
FireAm94's Avatar
It actually pushes the lifters on the cam lobes so it wouldn't help on that cam swap. It is cheap insurance though...i've seen guys spend alot more on crap that does absolutely no good whatsever and atleast this does something hehe.
Joe
Old Aug 14, 2003 | 11:38 AM
LWillmann's Avatar
And it's only like $230.
But would it cause increased wear on the cam lobes?
I realize that we're talking about roller lifters, but pressure on the lobes still has to be something of an issue to a certain degree.
Old Aug 14, 2003 | 11:55 AM
kmook's Avatar
Advanced Tech Moderator
Im gonna go with no.
Reasoning is if you think of a solid roller setup the spring pressures are much more than a hyd roller. So you should see a lot of wear on cam lobes on solid roller if that were true. So the extra pressure from a rev kit wouldnt were lobes if the spring pressure from a solid roller setup doesnt.
Old Aug 14, 2003 | 01:24 PM
BradZ28's Avatar
100 HP from additional pressure on the lifters at high RPMS.....ahhh no. I can understand the benefits of using this kit but where would the extra power come from?
Old Aug 14, 2003 | 01:28 PM
FireAm94's Avatar
Not floating the valves?
Old Aug 14, 2003 | 01:30 PM
kmook's Avatar
Its not going to gain you power unless you are already loosing power from floating valves, as mentioned above.
PCLZ28
Dec 24, 2015 05:19 PM
hotrod 5210
Dec 22, 2014 07:28 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
draven666
Nov 26, 2014 07:16 PM
ChameleonGreen
Sep 2, 2002 05:15 AM
