HVAC Compressor control 1994 Camaro
Old Jan 26, 2005 | 06:22 PM
yacka's Avatar
Recently purchased a 1994 Camaro LT1, air conditioner not working, had regassed but air comp not switching in. Appears that ECM not enabling the air comp relay to switch on. I can get the air comp to switch in by grounding the green/white wire from ECM, then the system works fine, however compressor is switched on permanently besides I want the system to function correctly. Auto electrician who has to rectify the system under warranty suggests he may have to pull dash out to get to an in cabin temp sensor? I think the ECM has triggered a trouble code and is not allowing the comp relay to switch comp on. Im in Adelaide South Australia - Australia (where!) and no one knows these cars here. can anyone help with diagnosing the ECM - im not sure if the service ctr's here have means of reading ECM codes and resetting? Help its damn hot down here!!
Old Jan 26, 2005 | 06:27 PM
Re: HVAC Compressor control 1994 Camaro
After the computer has disabled a/c function because of a problem, it usually has to be reset to allow operation again. Find the PCM BAT fuse in the dash fuse panel and pull it out for about 30 seconds. Put the fuse back and see if that allows a/c function again.
Old Jan 27, 2005 | 08:21 AM
yacka's Avatar
Cool Re: HVAC Compressor control 1994 Camaro
Thanks Rob, you hit it right on , I found fuse pulled for 30 secs and bingo ! all is fixed. I cant believe it was so simple. once again much appreciated.
regards a much cooler Yacka.
Scottylt1
Jan 8, 2015 02:48 PM
Scottylt1
Dec 4, 2014 12:31 PM
dreamer1q
Jul 24, 2002 04:39 PM
dreamer1q
Jul 9, 2002 05:37 PM
dreamer1q
Jul 8, 2002 08:47 PM
