Hung up on timing cover removal
Old Dec 1, 2008 | 09:30 PM
  #31
Stl94LT1's Avatar
Originally Posted by dubbsix
I've got the new cam in and now im getting ready to install the cam sproket and timing chain, but first I wanted to confirm that when installing the timing chain cover the cover goes on first and then the oil pan gasket mates up to it right?
Yes.
Old Dec 1, 2008 | 09:49 PM
  #32
dubbsix's Avatar
thanks. I guess i'll go ahead and install the cover
Old Dec 2, 2008 | 11:34 PM
  #33
merim123's Avatar
cover first, then oil pan is right. don't forget the rtv in the corners as per fel-pro directions.
Old Dec 4, 2008 | 02:38 AM
  #34
SS RRR's Avatar
If you do plan on using the same torn gasket, make sure to get sealant between the to ends of the gasket, top and bottom. After you get the pan bolted up let it sit for at least a day to cure before putting oil in or starting.
Old Dec 4, 2008 | 04:36 PM
  #35
dubbsix's Avatar
Oh im not going to reuse the torn gasket. Im going to replace the torn gasket. I had heard of a method of sliding the new gasket up along the side of the oil pan and then flipping it over.. but how low does the pan have to be to do that. I only have about 1" max between my block and the oil pan.
Im afraid of not lifting the engine up properly to clear the pan. I dont have any eyelets i can connect a hoist to and my jack probably wont be able to help me lift the car any mroe because the nose of the car is already on jack stands.
Old Dec 4, 2008 | 05:53 PM
  #36
Green96Z's Avatar
Pull out the motor mount bolts and put a block of wood under the accessory bracket or the bellhousing if you have an M6. Then jack it up as high is it will go. You need as much room as you can get. You will see when you get the pan low enough. The crank windage tray makes this very tough.
Old Dec 4, 2008 | 11:11 PM
  #37
dubbsix's Avatar
Has anyone used a hoist to do this? I would be much more comfortable with messing around with the through bolts if its being held up my a shop crane and not a jack.. Plus my jack is pretty much tapped out as the front of my car is up pretty high on jackstands.
HectorM52
Jul 30, 2017 11:46 AM
oldschool
Feb 9, 2016 09:21 PM
*Emilia*
May 13, 2015 09:05 AM
willismoons
Feb 14, 2015 08:42 PM
Queens94z28
Dec 20, 2014 09:11 PM
