HUGE Oil Leak =(
Old Aug 7, 2003 | 04:23 PM
  #16
InjectedSS's Avatar
well the verdict is in
my car was leaking a lil bit of oil the other night and it turned out to be the pan gaasket! well when i pulled the old pan gasket i guess theres like 2 lil shims that are on the back of the oil pan gasket (where the 2 NUTS go on the flywheel end) that are INSIDE the gasket to make it so u dont squash the gasket when you tighten the bolts.. well i guess when i took the old torn gasket out the two lil shims STAYED on the studs and when i put the new gasket in and tightening the nuts, they werent letting the gasket seal all the way cause they were causing it to hang up on the shims so i yanked them off and all is good now! i pulled the tranny also cause the bellhousing was full of oil so i had to clean all that crap out as well
ill post some pics later to better show what im talking about so that next time anyone that puts a pan gasket in wont let this happen to them
Old Aug 7, 2003 | 04:40 PM
  #17
xxsaint69x's Avatar
thats exactly what happened to me, and my friend. STUPID shim from the old gasket gets stuck on the stud and u cant see it!
Its kinda werid thou that u didnt have a leak for 4k. Glad u found it
Marcin
Old Aug 7, 2003 | 04:42 PM
  #18
FireAm94's Avatar
Wasn't the topic huge oil leak?
Part IV...please read your own topic before you post. The topic was HUGE Oil Leak =( in case you forgot.
Old Aug 7, 2003 | 06:23 PM
  #19
InjectedSS's Avatar
Originally posted by xxsaint69x
instead of bitchin go drop your tranny and find out for sure. ITs either your oil pan gasket or your rear main seal. GEt to work
lol oh i already started getting to work the second i made the post i by all means dont just sit by the computer and wait for people to work on my car for me i was just checking up on what people were saying thats all! if would have waited 5 more minutes you would have seen my "VERDICT" post
Old Aug 7, 2003 | 06:28 PM
  #20
InjectedSS's Avatar
Marcin
lol no no see what happened was when i put my motor together i used a brand new oil pan gasket! well it JUST started to leak 4k miles later! so i took it off LAST NIGHT and the reason it was leaking was it had a tear in it and wasnt sealing nemore! so i put ANOTHER gaSKET on last night and it leaked even worse.. due to the fact that those shims didnt get taken out when i pulled the orginal leaking gasket see what im saying
Old Aug 7, 2003 | 08:44 PM
  #21
InjectedSS's Avatar
yes and read my post where i said "NO ITS NOT AN INTAKE LEAK"
Magenta_Hearts
Mar 29, 2017 08:54 PM
surreybrad
Apr 22, 2015 06:40 AM
BigWil
Mar 29, 2015 12:24 PM
artic94
Jan 17, 2015 11:19 AM
