Hub removal/installation
Old Dec 17, 2011 | 01:51 PM
TeeTopZ's Avatar
I am going to install a new cam this winter and was wondering if someone on here has the Kent Moore hub tool that I could rent from them. Or if there is just a standard 3 hole puller from the parts store I could use. Also, if anyone one has the crane dual valvespring tool to rent, I would really appreciate it. Thanks
Old Dec 17, 2011 | 02:34 PM
raroz28's Avatar
Re: Hub removal/installation
Just buy yourself a crows foot puller, it works fine. However I helped a friend with his 94 and he said the crows foot didn't work cause the car didn't have the holes that line up. Not sure if it's true cause I have a 97 and have always used the crows foot.
You can rent the tool for the valve springs from autozone or advance, both of which require you pay the cost of the tool which you get back upon returning it.
Old Dec 17, 2011 | 05:33 PM
96 TA's Avatar
Remove and Install the LT1 Crank Hub | Tech Aids & Articles
hope this helps
AviatorDave
Dec 19, 2016 06:35 PM
Boss002
Jan 20, 2016 12:17 PM
Boss002
Jul 24, 2015 10:47 AM
RallyRed701/2
Jul 20, 2015 11:18 AM
cyteone
Feb 7, 2015 06:04 PM
