HuB HELP !!!!
Old Oct 16, 2006 | 07:38 PM
zoelt1 94's Avatar
HuB HELP !!!!
Could some one pls. tell me how to remove the hub on my 1994 z28 and if I need a speical tool pls post the part number.
thanks
Old Oct 16, 2006 | 09:21 PM
Severous01's Avatar
Re: HuB HELP !!!!
if you're talking about the wheel hub/bearings then you'll need to completely remove the brakes. look on the back of the spindle for a speed sensor, unclip. while back there, locate the 4 (i think they're 13mm, that or 15) 12-point bolts that go through the back of the spindle into the hub assy. remove them. if the bearing is stuck you'll need to lightly tap on the back to pull it free. it should just pop right out.
Old Oct 17, 2006 | 12:29 AM
SS RRR's Avatar
Re: HuB HELP !!!!
thanks
It is sold as an "assembly".
If it needs replacement you can get it for $115 before shipping from partsamerica.com. Or you can get it for that listed price from Advanced Autoparts if you have one in your area. Part number is: 513090
Old Oct 17, 2006 | 10:36 AM
zoelt1 94's Avatar
Re: HuB HELP !!!!
Thanks for the reply. I should have been more clear the hub I'm refering to is the one on the crank
AviatorDave
Dec 19, 2016 06:35 PM
Boss002
Jan 20, 2016 12:17 PM
Boss002
Jul 24, 2015 10:47 AM
RallyRed701/2
Jul 20, 2015 11:18 AM
cyteone
Feb 7, 2015 06:04 PM
