HuB HELP !!!!
Re: HuB HELP !!!!
if you're talking about the wheel hub/bearings then you'll need to completely remove the brakes. look on the back of the spindle for a speed sensor, unclip. while back there, locate the 4 (i think they're 13mm, that or 15) 12-point bolts that go through the back of the spindle into the hub assy. remove them. if the bearing is stuck you'll need to lightly tap on the back to pull it free. it should just pop right out.
Re: HuB HELP !!!!
If it needs replacement you can get it for $115 before shipping from partsamerica.com. Or you can get it for that listed price from Advanced Autoparts if you have one in your area. Part number is: 513090
cyteone
Feb 7, 2015 06:04 PM
