Hub and Crank Pulley help!!
Old Jul 28, 2009 | 06:49 AM
ptown's Avatar
I just instlalled a new hub from Thunder Racing. I noticed that it doesnt have any threads inside the hub for the hub bolt theat goes thru the center. The hub also has a little circular pin sticking out of the front of the hub at 12 o clock. It seems like that will hit my crank pulley when I install it. Anyone run into this before?
Old Jul 28, 2009 | 07:27 AM
F6's Avatar
F6
Remove the pin or cut it off.
Why should you have a thread inside the hub to fasten the hub to the crank???
Old Jul 28, 2009 | 08:06 AM
There are not supposed to be any threads in the center hole.
Old Jul 29, 2009 | 11:46 AM
mzgp5x's Avatar
I pulled the roll pin. Quite an improvement over the stock piece. Very good key engagement during installation. B
Boss002
Jan 20, 2016 12:17 PM
Boss002
Jul 24, 2015 10:47 AM
RallyRed701/2
Jul 20, 2015 11:18 AM
C4m4roJoe
Jul 19, 2015 10:59 PM
Catmaigne
Jul 14, 2015 05:17 PM
