HPP III tunning vs stock how does it effect fuel milage?
Old Nov 20, 2004 | 12:58 PM
Coolformula's Avatar
First of all yes I know PCformless is better(when I get a cam I will get it or tuner cat ...) but today going into the winter. I want better gas milage.
Would 180 tstat with stock pcm
or 180 with HPPIII tuning
Which would be better fuel milage the first and the 2nd for more performance thanks.
Old Nov 20, 2004 | 01:19 PM
Re: HPP III tunning vs stock how does it effect fuel milage?
The HPP isn't going to affect fuel mileage at all. It diddles with some WOT timing stuff. If you lowered the coolant temp, you might see a small drop in fuel mileage, but staying with the stock 180degF 'stat should not cause any change in mileage. The HPP also doesn't produce much in the way of power gains.... some people have dyno'd with the "power tuning" and found they lost HP.
Old Nov 20, 2004 | 03:11 PM
T/A#4's Avatar
When I did mine it sure helped with the fans & the overheating in traffic Also I did notice better SOP power.
Old Nov 20, 2004 | 07:48 PM
Yea thanks. I try to run the 180 in winter, so that is what I did today.
The cable with the GM obi is a parellel printer cable and going to the hpp, can I use that cable to my laptop with tuner cat instead of buying another cable from AKM??? thanks
What are the links for tuner cat
And the freescan program
Thanks in advance.
Old Nov 20, 2004 | 07:58 PM
madwolf's Avatar
You can only use a piece of your HPP cable. You will still need to buy the other piece from www.akmcables.com to use the HPP piece.
Get the one "for HPP" from them.
Tunercat
Freescan
canbaufo
May 25, 2015 12:01 PM
chuyz28
Jan 27, 2015 08:53 AM
LT1runner
Aug 3, 2002 05:44 PM
LT1runner
33
Jul 24, 2002 01:19 PM
