HP vs. Injector size
Old Jun 6, 2006 | 05:09 PM
Hawk944's Avatar
Maybe i'm just a dreamer but with the new setup i'm hoping/wishing for 500 to the flywheel. That seems a little to much for the 30 lb. pr hr. Would the 36lb pr hr be to much? And if so is there a way to cut them back? I'm a little new to the mysterious ways of Injectors/size and real hp mods. Thanks guys.
Old Jun 6, 2006 | 05:15 PM
Re: HP vs. Injector size
A good guideline (NA) is to multiply the flywheel HP by 0.07 to get your injector size.
500 x 0.07 = 35#/HR.
That assumes you have a decent, fairly efficient tune, and that you do not want to run above 85% duty cycle.
There is no real downside to an injector that is a bit larger than you need. As long as the PCM is programmed with the correct flow rate and offsets, it adjusts the pulse widths to deliver the required amount of fuel.
Old Jun 6, 2006 | 05:18 PM
MyShibbyZ28's Avatar
34lbs would be good just below 500. 36 would be a good size.
http://www.geocities.com/scwizzo/graph.jpg
HectorM52
Jul 30, 2017 11:46 AM
drptop70ss
Mar 26, 2015 01:50 AM
NewsBot
Jan 29, 2015 07:10 PM
NewsBot
Jan 11, 2015 06:10 PM
