hp gain from 1.6 rockers
Old Mar 3, 2006 | 04:05 AM
z275plus's Avatar
Question hp gain from 1.6 rockers
Is there any hp to be gained by changing from a comp cam 1.6 roller tip rocker and going to a pro mag 1.6 ?
And how far should you adjust the rockers.Gm stated 1 full turn from 0,some say 1/4 turn,some say 1/2 turn,tpis stated 1 1/2,which one is right. The cam that is being use is the lingerfelter 211/219 cam. I do not want to adjust them too tight.
Old Mar 3, 2006 | 10:04 AM
Cmr0z28's Avatar
Re: hp gain from 1.6 rockers
You might see 2hp...
I went 1/4 turn past 0.
Old Mar 4, 2006 | 11:57 AM
Compstall's Avatar
I know what you mean. I ended up kind of averaging all the different answers, and I just do a 1/4 to 1/2 turn past Zero. The rocker adjustment is pretty forgiving though.
Old Mar 4, 2006 | 12:36 PM
396D1SS's Avatar
you will see more then 2hp I say about 7
Old Mar 4, 2006 | 01:20 PM
Compstall's Avatar
I doubt it because he's already starting out with the 1.6 lift numbers. The only gain he might see is through the trunnions of the full roller rocker.
13qtr
Oct 28, 2016 08:11 PM
95chwagon
Oct 16, 2015 12:24 PM
football4life
Oct 4, 2015 07:48 AM
9t4lt4z28
Oct 2, 2015 10:28 AM
colts0455
Sep 22, 2015 02:03 PM
