HP and crankcase pressure
Old Aug 19, 2007 | 03:32 PM
Z-RATED94's Avatar
Is there a point in which crankcase pressure becomes an issue? Or is it that most of us will never hit that HP level. At 500rwhp would it be a concern? Thanks, Rick.
Old Aug 19, 2007 | 08:40 PM
I run the stock PCV system at the 800 flywheel HP level with no problems.
Old Aug 19, 2007 | 09:30 PM
96capricemgr's Avatar
I think bore quality is the real issue here. If they are not straight anfd true they wont seal and crankcase pressure could rise badly at low power levels.
Old Aug 20, 2007 | 01:00 AM
OneFlyn95z28's Avatar
I am running over 750FWHP and over 800FWTQ on Juice. I hit mine with about 285FWHP out of the hole. I have never had any luck with the stock PCV system. Alway dumping oil in my intake since the day I bought the car.
With no vacuum on the Crank case Mine make a little pressure in the bottom end. time to add a vacuum pump
KYWes
Jun 14, 2022 06:52 AM
canuck94z28
Aug 19, 2015 05:50 PM
karpetcm
Aug 14, 2015 03:02 PM
350350
14
Aug 11, 2015 12:03 PM
RX Speed Works
Jul 24, 2015 02:25 PM
