HP and crankcase pressure
Is there a point in which crankcase pressure becomes an issue? Or is it that most of us will never hit that HP level. At 500rwhp would it be a concern? Thanks, Rick.
I am running over 750FWHP and over 800FWTQ on Juice. I hit mine with about 285FWHP out of the hole. I have never had any luck with the stock PCV system. Alway dumping oil in my intake since the day I bought the car.
With no vacuum on the Crank case Mine make a little pressure in the bottom end. time to add a vacuum pump
14
Aug 11, 2015 12:03 PM
RX Speed Works
Jul 24, 2015 02:25 PM
