How would i test my electric water pump?
Old Mar 15, 2008 | 11:10 AM
fstenuf's Avatar
i need to check my electric water pump to see if it's working. How big of a power source do i need to see if it starts up?
Old Mar 15, 2008 | 11:23 AM
Pontiac_97's Avatar
12v?????
Old Mar 15, 2008 | 11:26 AM
rcantrellz28's Avatar
12vt........ Just plug the power wire to the battery and the neg. to the negative post. I beleive it is not a good thing to run one dry for too long however, so dont let it run long at all
Old Mar 15, 2008 | 11:30 AM
fstenuf's Avatar
k good deal. i was gonna hook it to my battery but i didn't know if that was too much of a power source. Guess i'll give it a try and see what happens! Thanks guys
Old Mar 15, 2008 | 11:31 AM
Power supply should be capable of supplying at least 10amps at 12V.
Old Mar 15, 2008 | 12:49 PM
Too much? No such thing if you are using the car's battery.
Old Mar 15, 2008 | 10:50 PM
Steve in Seattle's Avatar
This is why I always use dual-post batteries... the side posts run the car, the top posts are great for testing 12v items (like bulbs, pumps, etc..)
Use 14 AWG or better wire, a fuse holder, and aligator clips for the "test side", and ring terminals for the top post. heat-shrink the wires together is a nice touch... voila, life-long 12v tester.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Queens94z28
Dec 20, 2014 09:11 PM
Zone
Jul 29, 2002 07:43 PM
