How weak are the factory lt1 cranks?
Old Sep 22, 2005 | 01:22 PM
  #16
SStrokerAce's Avatar
Re: How weak are the factory lt1 cranks?
Originally Posted by CANTONRACER
IMO...a stock crank in conjunction with some good studs and a good line bore can take more punishment than most on this board will even get close to.
Only need to line HONE that setup...
But yeah a stock crank that is magnafluxed and polished usually will take a ton of abuse IF you aren't detonating like a champ AND it's balanced correctly.
Bret
Old Sep 22, 2005 | 01:26 PM
  #17
CANTONRACER's Avatar
Thinking a 4 bolt conversion...do not want to give people bad advice...
Old Sep 22, 2005 | 04:12 PM
  #18
Understandable but a 2 bolt studded block is stronger than a stock cast crank..... kinda pointless until you get into the area were you need a forged crank.
Bret
Old Sep 22, 2005 | 05:01 PM
  #19
67camaro02's Avatar
Ok, how about an aftermarket cast crank (eagle) I bought a 383 stroker motor that was buils with cast eagle crank...unsure of the rods and KB hyper pistons....
I dropped a valve and have the heads off...I was gonna replace the internals with forged components. My goal is 400+ RWHP N/A and 600+ RWHP n2o (wet kit/hopefully direct port)
Would I be better of spending the money on rods and pistons and sticking with the crank I have?
Old Sep 22, 2005 | 05:44 PM
  #20
Yes... a set of Eagle or Scat I beam rods should be enough but you might have them already.
bret
Old Sep 22, 2005 | 07:58 PM
  #21
96capricemgr's Avatar
Originally Posted by simple
that aint no ****, them b-body boys make those cars run hard
and they weigh in close too 4000lbs
A few extensively lightened cars have raceweights with driver as light as 4000lbs. Most cars are over that without driver these are porky cars, but the full frame 8.5" 10bolt and such make them take abuse very well, plus we have room to work on our drivetrains and a fuel pump is at most an hour job .
As with anything the stock crank has limits but few here are going to push them.
Old Sep 23, 2005 | 07:48 AM
  #22
67camaro02's Avatar
I'll start another thread instead of whoring this one
Last edited by 67camaro02; Sep 23, 2005 at 08:02 AM. Reason: starting another thread
Old Sep 23, 2005 | 03:37 PM
  #23
WS Sick's Avatar
I run a cast steel eagle crank to around 6800 rpm pretty regularly. I have over 50 1/4 mile passes on in in just the last 2 years.
Old Sep 23, 2005 | 03:58 PM
  #24
LT1Squirrel's Avatar
Also a supercharged car puts a lot more stress on the crank than say an all motor or juiced motor
Old Sep 23, 2005 | 04:23 PM
  #25
Actually a juiced motor hurts the crank more, a blower motor just hurts the crank snout more.... either way detonations hurts them more than anything.
Bret
Old Sep 23, 2005 | 05:28 PM
  #26
Kory 88 Iroc Lt-1's Avatar
I'm thinking about doing a turbo next year. I have a nice set of forged pistons. I was thinking of going with some h beam rods. how much power could I make at or below 6500rpms before the properly prepped stock crank would be the weak link?
Thanks,
Kory
Old Sep 23, 2005 | 08:37 PM
  #27
Bret
i always thought that the snout getting pulled a lot harder at a strong angle would throw off the geometry, thus that being more hazardous...but i guess both can do damage
Old Sep 24, 2005 | 12:50 AM
  #28
Loadre's Avatar
A large shot of nitrous creates HUGE cylinder pressures. The blower just tries to rip the end off the crank, nitrous tries to twist the damn thing in half each time a spark plug fires.
Old Sep 24, 2005 | 07:25 PM
  #29
ah...so i guess pulling a band-aid off your forearm is better than chopping it off at the elbow
Gtpguy
Jan 26, 2015 04:50 PM
cmdeshon
Jan 4, 2015 11:15 AM
Brandon Wittmer
Dec 20, 2014 09:51 PM
1LEThumper
Jul 14, 2003 12:45 PM
