How hard is a cam swap?
Old Sep 23, 2005 | 12:04 AM
jasons93z's Avatar
Not just that. What all is needed? How much time? Which cam should i go with, i dont care about gas mileage. My car has 105k on it, what else should i replace. I know quite a bit about these cars. I have done the headers, rebuilt opti, waterpump, by myself. So i think i can do it.
Old Sep 23, 2005 | 12:06 AM
SuperDavez28's Avatar
Re: How hard is a cam swap?
The bottom end or at least freshen it up with some new bearings would be my advice
Old Sep 23, 2005 | 12:08 AM
madwolf's Avatar
This topic is discussed almost daily. Try doing a search.
Old Sep 23, 2005 | 12:11 AM
jasons93z's Avatar
i go to school for med-school, im not a mechanic, and i cant just lift the engine
Old Sep 23, 2005 | 12:12 AM
jasons93z's Avatar
why post if your not going to help??? Im at work and have limited time
Old Sep 23, 2005 | 12:17 AM
jasons93z's Avatar
oh, and i went back to the stock 1.5 rockers with lt4 springs. What cam can i go with without getting close to coil bind?
Old Sep 23, 2005 | 12:18 AM
madwolf's Avatar
Because it takes less time to do a search than to post a new thread. I've answered this same question at least 5 times already.
Shoebox's cam install page.
Trust me it takes a lot more research than u can do in one night.
Old Sep 23, 2005 | 12:21 AM
97BBlackZ's Avatar
In a way he is helping. Through a search your going to find WAY more info then anyone will ever post in your thread.
People cant just pick out which cam is for you your going to have to do some research. What kinda of gains are you looking for how much drivability do you want to lose? Who are you going to get to tune it? ect.
And some LT1s (mostly high mileage/ even some low ones) are know to throw bearings after cam installs.
jasons93z's Avatar
People cant just pick out which cam is for you your going to have to do some research What kind of stall do you want to go with how big does it need to be if you have an a4. What kinda of gains are you looking for how much drivability do you want to lose? Who are you going to get to tune it? ect.
only if you get **** dirty.
Old Sep 23, 2005 | 12:25 AM
madwolf's Avatar
A messy install is just one factor in possibly ruining the bearings.
Most people with higher mileage will ruin them because they've reved it all 100K up to 5500 RPM and then they go 6500+.
Either way you look at it, the bearings are weaker with more mileage on the engine. Many don't like the stress of the new power and/or new rpm range.
Old Sep 23, 2005 | 12:42 AM
Z95m6's Avatar
A hot cam is about the only cam you can install with out changing springs.
Old Sep 23, 2005 | 12:13 PM
Jazsun's Avatar
would a hot cam, lessen the chance of spinning bearings ona 100k motor? I heard hotcams are quite mild especially the LT1 hot cam, My car would still be shifting at 5500 RPM even w/ a new cam because its a non electric auto. Basically my engine has good compression, all around 200ish +-20. Is throwing a cam in just gona kill my motor faster? Im talking about a mild cam like the hot cam one. I already have springs/rockers so it is ready for a cam. Thanks.
Old Sep 23, 2005 | 12:46 PM
turbo_Z's Avatar
Cam swaps are risky if you dont keep everything clean... doesnt matter what cam you install. The biggest factor IMO is how well taken care of the motor was before the cam install and not necessarily the mileage. Lets say the oil changes were done ever 3k miles and a lot of those miles were rolled over on the highway, then you are better off. Where you find problems is when you tear into a motor that has sludge all over the heads and in the lifter valley because that crud gets knocked down in the motor and runs thru the bearings... the chances are greater that the debris will get clogged either in the pickup screen or in the oil passages. When that happens you will need a rebuild!
Old Sep 23, 2005 | 01:31 PM
93ZM6Tally's Avatar
The cam installation in itself isn't risky IMO, it's how the car is driven after the install. Most guys get "happier" with the right foot after the install and accelerate the wear process on an already tired motor. FWIW I put a GM847 in a car with about 80k, never had a problem related to the cam install, 20k later I'm rebuilding, but not because I had to, because I wanted to. If you want to put in a cam go ahead, not that difficult, as posted above, if the engine breaks, oh well, fix it.
